YB cam choices??
YB cam choices??
Hi all, I have a rebuilt 2wd engine running 4x4 pistons. Does anyone know what my cam choices are before the valves will clip the pistons? Also any idear what compession ratio i have??
i heard that lowers compression to around 7.9-1 but not 100% (head being skimmed will alter it too) would be interested in the cam situation as i am on a standard engine and would maybe like to up the inlet,i know you can run a bd10 but i heard they are crap lol,can you get a bd14 without pistons mods in and without double valve springs?
if i installed a bd14 inlet cam to my standard engine do you just set the cam timing as you would standard and would not touch the pistons or do you need to adjust it to stop valves hitting?
