starter motor problem
Old Sep 28, 2008 | 09:50 PM
Smartdj.'s Avatar
Smartdj.
Default starter motor problem
could anyone tell me if there is suposed to be a groung straight from the battery bolted thru the started to the gearbox..i just want to make sure i have it wired up properly
Old Sep 28, 2008 | 09:51 PM
Smartdj.'s Avatar
Smartdj.
if this is wrong could it wreck the altinator
Old Sep 28, 2008 | 09:52 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Yes.
Old Sep 28, 2008 | 09:53 PM
Smartdj.'s Avatar
Smartdj.
it is suposed to be there....well why the hell wont my car start..it just goes donk
Old Sep 28, 2008 | 09:58 PM
Dangerous Malcolm..
A donk doesn't sound good.
But yes, the starter has a direct +ve and -ve feed because of the juice it needs.
Old Sep 28, 2008 | 10:02 PM
Smartdj.'s Avatar
Smartdj.
it makes the same noise my old starter made ...cant be the flywheel..cnt be the starter...........????????????????????im stuck.......my battery is not in the best condition but even tryed jum starting it off another running car and a batery pack still wont turn over....and hitting it with a hammer
Old Sep 28, 2008 | 10:06 PM
Dangerous Malcolm..
The engine isn't seized is it?
Old Sep 28, 2008 | 10:08 PM
westus1's Avatar
westus1
sounds like the engines locked up mate
Old Sep 28, 2008 | 10:09 PM
Smartdj.'s Avatar
Smartdj.
no i just rebuilt it and i done it properly.it did turn over on the old starter once but then it died..i cant bump it donw the road because i havent primed the engines oil presure because of no starter..not sure what to do
Old Sep 28, 2008 | 10:11 PM
westus1's Avatar
westus1
try turn the engine by hand, if thats ok then you got a faulty starter or maybe a bad earth
Old Sep 28, 2008 | 10:12 PM
Dangerous Malcolm..
Try turning it over by hand on the crank pulley.
Old Sep 28, 2008 | 10:13 PM
Dangerous Malcolm..
Just beat me to it.
Old Sep 28, 2008 | 10:18 PM
Smartdj.'s Avatar
Smartdj.
is it good to take the plugs out when turning the engine over for the fist time intill u get oil presure i over herd a convosation of somone with a rst..he was saying its the best way??personally i cant see how
Old Sep 28, 2008 | 10:22 PM
Dangerous Malcolm..
Plugs are ok left in but I'd pull the fuel pump relay so it doesn't fire.
westus1's Avatar
westus1
just disconect the coil, same thing as you do when fitting a new turbo
gets the engine spinning without it firing up, helps get oil to everywhere its got to be before its running
Old Sep 28, 2008 | 10:23 PM
Smartdj.'s Avatar
Smartdj.
off th e top of my head there is two wires tht plug into the posotive then a little round one which conects next to the posotive then a negative bolted to the box thru the starter..correct yeh
Old Sep 28, 2008 | 10:26 PM
westus1's Avatar
westus1
yeah thats right, there should be a bid heavy red wire(maybe 2, the other 1 just feeds the alt), and a bid heavy earth cable going thru 1 of the mounting bolts, the small wire is the feed from the ignition switch
sounds like you got it wired ok
Old Sep 28, 2008 | 10:27 PM
Smartdj.'s Avatar
Smartdj.
good idea about pulling the fuel relay..cant flod it then.
and i have the coil unpluged ...plus i still dont kno if i have the right fireing sequence lol
Old Sep 28, 2008 | 10:29 PM
Smartdj.'s Avatar
Smartdj.
if the wirings ok could be a duff battery but with jump leads it should atleast turn over shouldnt it..cant be that fucked
Old Sep 28, 2008 | 10:30 PM
westus1's Avatar
westus1
should turn with jump leads even if the battery's down
firing order is 1342
but it would still turn even if thats wrong
Old Sep 28, 2008 | 10:36 PM
Smartdj.'s Avatar
Smartdj.
1342 ona s2 yeh
Old Sep 28, 2008 | 10:40 PM
Smartdj.'s Avatar
Smartdj.
this dosent make any sense the starter i just fitted came off car that was running ..can they just brake after sitting in the gArege for 4months surley
Old Sep 28, 2008 | 10:46 PM
Smartdj.'s Avatar
Smartdj.
anyways thanks for your help boyzzzzz
cossie362
Oct 11, 2015 03:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
