Engine life
Old Sep 26, 2008 | 10:51 AM
Connor's Avatar
Connor
Default Engine life
My Focus 1.8 16v zetec has 106k on it
Burns no oil
Doesnt use water
Has a full mongoose system on it and a K=n with the recent addition of 18 inch wheels
I have owned it 4 weeks
Runs spot on
I have some cams to go in it. Kent stage 1
Can I just go ahead an fit them an its job done. Will reset the timing aswell.
I will be getting a remap in the coming months aswell to cmpliment this
What gains will i see with just cams?
Will it be noticeable?
Will it kill my engine.
Bearing in mind i have just done all the belts and a full service
Thanks in advance
Old Sep 26, 2008 | 11:16 AM
Connor's Avatar
Connor
I dont hammer the car either
Any info would be great
Old Sep 26, 2008 | 11:52 AM
Connor's Avatar
Connor
anyone????
Old Sep 26, 2008 | 12:49 PM
Connor's Avatar
Connor
anyone
Old Sep 26, 2008 | 01:00 PM
Harris.'s Avatar
Harris.
Cant see any of the above giving you problems
Old Sep 26, 2008 | 01:42 PM
Connor's Avatar
Connor
quality just won some OBX pulleys on ebay for Ł51 in blue just paid for them the now
Should make for a fun evening this week
Just need the torque settings for the cam shell/covers now - NOT the rocker cover
Old Sep 26, 2008 | 01:45 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Were will you be going for your remap, be careful as there are alot of cowboys out their. You would be good to find an EvolutionChip dealer in your area.
Benni.
Old Sep 26, 2008 | 01:50 PM
wirralphil's Avatar
wirralphil
According to the TIS Workshop manual for the Cam Caps it is
Stage 1 = 10Nm
Stage 2 = 19Nm
Old Sep 26, 2008 | 03:40 PM
Connor's Avatar
Connor
i have that manual installed it on my PC an it wont open anything mate
Any tip s
Old Sep 26, 2008 | 03:43 PM
wirralphil's Avatar
wirralphil
I have it on CD, maybe worth trying that then running it.
Old Sep 26, 2008 | 03:53 PM
Connor's Avatar
Connor
yea it let me install it but im unsure what to open or any of that mate
Old Sep 26, 2008 | 03:54 PM
JamesH's Avatar
JamesH
Whilst you're at it I'd consider doing the head gasket if its not been done already with 100+k
Old Sep 26, 2008 | 04:02 PM
BM08's Avatar
BM08
+1
My dads had his engine changed in his zetec escort estate, its the 1.6 version but similar engines.
The head went on that at about 100k, and also make sure you check the engine regular because my dads 10month old 60k engine which he had put in overheated yesterday, it was about 5mins away from frying the engine
The verdict? still at the garage.
Its not all bad though, i owned an escort gti for 2 and a half years, never had one single engine problem, apart from the reving high issues most zetecs get, which was easily fixed
Old Sep 26, 2008 | 05:15 PM
pani_k's Avatar
pani_k
PassionFORD Member
My Focus 1.8 16v zetec has 106k on it Burns no oil Doesnt use water Has a full mongoose system on it and a K=n with the recent addition of 18 inch wheels I have owned it 4 weeks Runs spot on I have some cams to go in it. Kent stage 1 Can I just go ahead an fit them an its job done. Will reset the timing aswell. I will be getting a remap in the coming months aswell to cmpliment this
What gains will i see with just cams? Will be noticable mostly after 3500rpm much better mid range pulling to 6k rpm
Will it be noticeable?yes
Will it kill my engine. no
Bearing in mind i have just done all the belts and a full service Thanks in advance
Hope this helps
Old Sep 26, 2008 | 07:53 PM
Connor's Avatar
Connor
yep perfect mate
Hmm my mates modeo 1.8 went to 182k before the head went. Did the head an 2 weeks later the engine ceased
Old Sep 26, 2008 | 08:21 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
my mrs 1.8 focus has just hit 170k, never had to do anything to it yet engine wise, still runs spot on, uses no oil or water
Old Sep 27, 2008 | 12:01 AM
LHD220Turbo's Avatar
LHD220Turbo
without wishing to sound rude, you're better off not bothering with the cams and fit the st170 mainifold as the focus one you have is very restrictive
the cams might reduce low/mid range torque, and give you a little more power much later in the rev range
Old Sep 29, 2008 | 08:21 AM
Connor's Avatar
Connor
Thats not rude at all mate
Right i have been told a few times about the ST manifold but was wonderinf would i be better with the ST manifold or a 4-2-1 manifold??
Thanks
Old Sep 29, 2008 | 05:45 PM
pani_k's Avatar
pani_k
PassionFORD Member
A 4-2-1 from Piper or Millitek would be just as good imo but the ST170 manifold is renowned for giving the best overall gains all across the rev range. Either of the 3 are excellent manifolds though and all high quality items.
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
gcfcos
Shows & Track Days
Aug 31, 2015 08:13 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
