fitting 4wd engine into 3 door???
could any 1 tell me what i need to swap by fitting a cosworth 4wd engine into a 3 door?
i know i will need to swap the sump but will i need to swap the oil pump and pick up pipe??
anything else inside i will need to swap??
will i need to swap the oil filter as the 4wd is different??
engine mounts??
engine mounts??
you need full 4x4 front cross member with rack and mounts,
you need sump and pick up pipe and pump,
you also need to mod the tunnel,
obviously you need front diff and box and both props etc
also need to move the oil filter
need 4x4 front hubs, brakes and struts
dont expect to do it in a day mate
i picked that up wrong mate
swap over the sump pick up pipe and pump
the adapter for the filter can just be taken off,
2wd mounts will swap straight onto the 4x4 block
water pump and pipes are differant(your ok if you use 4x4 pipes as well)
turbo oil feed pipe is shorter 2 if its 4wd head
2wd turbo damper wont fit 4wd head either
never tried leaving the relocator for the oil filter on when using 2wd mounts so not sure, but think its in the way, all it does is move it out the way of the mount anyhow, just take it off if its in the way
thats it for internal engine stuff mate
COSWORLD
14-08-2015 07:40 AM
track.focus'd
12-08-2015 05:53 PM
lockie
31-07-2015 10:03 PM
