LSD BOX Identification?
Old Sep 9, 2008 | 05:20 PM
mercury grey minter's Avatar
mercury grey minter
Default LSD BOX Identification?
How can you tell on a s2 rs if it's an LSD box and not a cheap 3i or diesel box.
Iv'e heard it's something to do with spinning the wheels.
Old Sep 9, 2008 | 05:58 PM
jonesymk2's Avatar
jonesymk2
if you look through the hole where the driveshafts go into the box,the lsd box you can see straight through,the xr box and other boxes has a bar going across the hole,i also think that when you spin 1 wheel with the lsd box the other wheel should turn the opposite direction
Old Sep 9, 2008 | 06:51 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
when you spin the wheel if its jacked up the other wheel should spin the same way shouldnt it.
Old Sep 9, 2008 | 08:19 PM
mercury grey minter
Does anyone know a sure fire way????????
Old Sep 9, 2008 | 08:24 PM
Oranoco's Avatar
Oranoco
Jack it up so both front wheels are off the floor then spin one wheel by hand. The other wheel will spin the same direction if it has an LSD
Old Sep 9, 2008 | 08:26 PM
mad dog younge's Avatar
mad dog younge
yeh mate look through the hole where the drive shafts go and it shud be flat .if it got a bar across its a piece of shit 3i
Old Sep 9, 2008 | 08:30 PM
mercury grey minter
Cheers guys,will check it out.
Old Sep 9, 2008 | 08:38 PM
NEWTON's Avatar
NEWTON
if you look were drive shaft goes,there will be no bar,just a hole
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
