Stack sensors wiring
Old Sep 8, 2008 | 02:24 PM
Rippers's Avatar
Rippers
Monte Geek
Default Stack sensors wiring
EDIT: just found the answer, they use mini sureseal fittings
Old Sep 8, 2008 | 03:31 PM
NEIL A's Avatar
NEIL A
Might aswell jump onto your post Paul if thats ok.
For the Stack fuel level do you need to run the sensor wiring the length of the car or just tie into the original wiring for the orighinal gauge behind the dash.
Also is there a site to find out the sizes needed for the wheel sensor.
Old Sep 8, 2008 | 03:40 PM
Rippers's Avatar
Rippers
Monte Geek
From the single wire behind the dash mate
With the wheel sensor size, each tyre wears and has different pressures adjust the size aswell so you need to measure the actual circumerance of your tyre your self. I did mine with a tape measure, I then compared it to the GPS on the Tom Tom and adjusted it very slightly till it was spot on
Old Sep 8, 2008 | 03:46 PM
NEIL A's Avatar
NEIL A
Thanks Paul will get a shot of asat nav and adjust as i go, only need to run the coil pick up and wheel sensor then should be easy enough.
Old Sep 8, 2008 | 04:26 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
All taken care of for you with full destructions on how to wire it all in .
The only thing that IS tricky / pain in the arse, is that you have to COMPLETELY drain your tank and then refill it in 6 litre increments (10 of them, with the last 5-6litres you tell it that it is full) and tell the Stack that this equates to 6, 12, 18, 24, 30, 36, 42, 48, 54, 60 and 65 litres. Once you have done this once - job done. However, MAKE SURE YOU FOLLOW THE PROCESS EXACTLY, as it is a real bitch if you fuck up, as you have to drain the tank and start again .
Old Sep 8, 2008 | 04:29 PM
dave cos4x4's Avatar
dave cos4x4
do you have to do this to used stack dash's Mike.
Old Sep 8, 2008 | 04:34 PM
Mike Rainbird
Caraholic
Yes, how else do you think that the Stack knows how much fuel is in the car ?
You have to remember that the float that is connected to the gauge just gives off a voltage signal from 0-5 which is then interpretted by the fuel gauge as to what position it is in and how that equates to fuel quantity. As the Stack is more accurate, you have ten measuring points to program in, which it will then extrapolate between to give a precise figure in litres (rather than just full, ¾ full, ½ full, ¼ full and empty). This means that you have to do the process above, so that the Stack knows what position the float is in. Obviously it is individual car dependent, as the float gets moved when the fuel pumps are changed, so Ben's figures might be close, but they won't be accurate.
Old Sep 8, 2008 | 04:36 PM
NEIL A's Avatar
NEIL A
Thanks Mike just got back from Ibiza so only started to read the instructions, gutted as my tank is neary full
I take it the oil will get sent to my normal address.
Old Sep 8, 2008 | 04:45 PM
Rippers's Avatar
Rippers
Monte Geek
I did mine buy running it untill the standard Ford low fuel light came on, went to the petrol station stuck 10 litres in set this as empty so I had a reserve, then put 5 litres in at a time till it was full
Old Sep 8, 2008 | 04:50 PM
dave cos4x4
thankyou Mike.
i will be looking for this post when its time to put it in...whenever that is..
NEIL A's Avatar
NEIL A
How much does the standard tank hold will get a few jerry cans and drain mine into them.
Old Sep 8, 2008 | 04:51 PM
dave cos4x4
normally 60 litres.
Mike Rainbird
Caraholic
Yep, will sort that out this week, but you need to send me your normal address remember ?
Mike Rainbird
Caraholic
normally 60 litres.
Sierra's are 60 litres, Escorts are 65 litres, have managed to squeeze over 65 litres in before .
Old Sep 8, 2008 | 04:54 PM
Mike Rainbird
Caraholic
Bizzare way of doing it, as the Stack has a facility for you to program in the reserve fuel level anyway . As in, you can set the reserve light to come on at any level you like. I drained my tank and told the Stack to trigger the fuel light on at 10 litres (similar to the standard car).
Old Sep 8, 2008 | 06:30 PM
Rippers's Avatar
Rippers
Monte Geek
I understand what your saying but it works for me and I like having a reserve of fuel so that I never ever run out
Old Sep 9, 2008 | 08:11 PM
NEIL A's Avatar
NEIL A
What wire behind the dash is used for the fuel gauge sensor, one of the ones from the multi plug or the two bullet connectors.
Old Sep 9, 2008 | 08:46 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
mike, what happens if you have a 50l tank lol did you say it needs 10 levels, so 5l a time if it is 50l lol
think the fuel level gauge in the pro alloy tank is a VDO one, i do hope this will work?
ive not even opened the gauge yet lol, so not read the instructions lol
oh, how long does it take to do, and dont the people in the petrol station look at you a bit funny lol?
Old Sep 10, 2008 | 07:22 AM
Mike Rainbird
Caraholic
It should all be in your destructions that came with it from us?
Old Sep 10, 2008 | 07:23 AM
Mike Rainbird
Caraholic
The above info is for the ST8100 range, you would have to follow the destructions for the 52mm item (I've not yet fitted one) .
I've never done it at a petrol station and if there was a big queue, I doubt they would be best pleased .
Old Sep 10, 2008 | 10:22 AM
NEIL A's Avatar
NEIL A
Nope mike i only have the Stack book that says take it straight from the sendor in the tank, and a piece of paper for the plug for the idiot lights.
Old Sep 10, 2008 | 10:28 AM
Mike Rainbird
Caraholic
Oops, should have been in the destructions. You just need to connect the Stack wire to the brown with black stripe wire in the multi-plug in the dash, which is the fuel sender wire .
Old Sep 10, 2008 | 07:38 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i guess ill have to have a look then lol
so can it be done in stages, ie fill it up with one jerry can, piss off to the petrol station for antoer and go back lol?
i only have 1 jerrycan lol
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
Mc5506
Sep 29, 2015 09:06 AM
