View Poll Results: T4 or Gt30
T4
53
36.30%
GT30
93
63.70%
Voters: 146. You may not vote on this poll
t4 or Gt30 for 500bhp
#81
Its all horses for courses, you can achive 500bhp either with T4 or GT30 so its bascially all down to the tuner you use as to what they prefer/what they recommend or what you personnaly want to achive with your own engine and how much you want to throw at it.
Personnaly i went the T4 route and am more than happy with the outcome
#82
DANISH cosworth abuser
Nice statement!? is that based on a poorly specked engine running T4 then? Nothing wrong with a well specked engine and a T4 either mate.
Or should i attack you for not going the gt-35 route that i am?
#84
P.S if i wanted to go GT35 I could have but i think 500BHP is more than enough for a road car!
#87
i was only saying i ithink they are better to drive and yes you are right its up to what the perticular person wants
#88
To be honest, i would actually agree with him, BUT the new t4 with gt housing and ballbearings are actually good for an internal wg turbo, but a gt 3076 on external wg will beat it if u ask me
#89
Caraholic
Nope. See previous page . The point I was making is that it is possible to have the best of both worlds (strength of a T4 / response of a GT30), by applying current technology to older turbos. This then negates all the issues with packaging, reliability (turbo and wastegate) and additional costs required with an externally gated turbo.
There would have to be some SERIOUS improvements for me to switch to a GT turbo (I only want 500bhp), and there are NONE at this power level, only what people "assume" as they have not explored the other possibilities, or are basing their opinion on poorly specced T4 engines (there is NOTHING worse than a poorly specced T4 engine for lag and response).
#92
Yep you are probably right, but is the person who only uses there car on the road (eg motorway madness), going to really notice the difference between the T4 and GT30? if both are on properly specked engines for 500 BHP?
#93
#95
#98
What does a fully modified t4 coast? 1400Ł something?
I gt30 is arround 850Ł plus 200 for the manifold + 200 for a cheap wg + 50 for some pipe fo the dp and 120 for a boost controler.
Hmmmm, i´m thinking gt30 here
#100
Mike i still think its is funny that you think someone with the development budget/facilities like Honeywell/garrett would develop a turbo that WASN'T any better than something they produced 25 years ago.
There have been huge advances in most technologies over the past 25 years so why would you not expect this to apply to turbochargers??
I can just see it now...
Mrs Rainbird - "Mikewoo woo, i want the 48 inch LCD with HD, dolby surround sound and built in sky plus hard drive"
Mike - " Sorry honey, you just cany beat a cathode ray tube and that crisp mono sound"
#101
#102
Why bother modding it in the first place if you are only interested in the magic 500? (as per title of this thread!) As i said earlier ITS ALL DOWN TO HOW YOU WANT YOUR ENGINE TO PERFORM.
#106
You can get a t34 to work like a t4 does, and vice versa depending on the above
#111
Caraholic
Er, regarding the shaft - why don't you look at the photos I posted up on the previous page, instead of jumping to random (incorrect) conclusions .
If you think the T4 has badly designed / inefficient wheels etc, perhaps you should compare compressor maps. From what I have seen, the T4 is still the Daddy....
The ONLY improvement with the GT30 (0.63 a/r) compared to the T4 is in boost-threshold, but at the expense of top end flow (500bhp @ 32psi is it's limit) AND strength. The only way the boost threshold is improved, is due to the lighter weight of the GT turbo's shaft (for a better reciprocating mass), but this makes it inherently weaker than the T4 item. If this is so important to you, and you want to pay for all the associated paraphanalia that goes with an externally gated turbo, then that is entirely your perogative.
However, I researched the differences, and for a 500bhp track car, I stuck with the shonky T4. It's up to you to chose what you want, but don't think that just because something is newer, it is better.
I'm sure Tony would back me up on this, if he wasn't still sulking at me .
A standard T4 may be limited to 520 bhp @ 32psi, but the one I pictured previously (with the mods to the exhaust housing) has produced 500bhp AT THE WHEELS (see Euan's graph).
#113
1st to 200 without NOS
IMHO There is only one reason why you would fit a T4 over a GT series and that's packaging.
Oh and reliability problems ?? What problems I used a GT series and battered it on the Gumball, Lee did the same any failures?.. Not here!
#116
ok ignore the modded T4 for a minute (and mike, just for the modded bit mike!), basically we all know a T4 will work for 500 and so will the GT30, so at the end of the day it comes down to whoever and however the person chooses to build the engine and how well it is speced and put together. old technology or new they both work for the the big 500 choosing either way they will have a quck car if done right!
#117
A gt-30 can also come with internal wg btw, even in trim 82 and that will make the t4 look bad in my appinion.
#118
#120
