5 cylinder compatible mappable ecu's
except megasquirt, emerald, anything that runs wasted spark.....
I assume SM4 will do it on individual coilpacks, how about the older mbe and dta stuff?
*** Sierra RS Custard ***
Do you mean NOT on a dizzy?
Yeah SM4 will do it quite happily, as will modern DTA (well not the real basic ones like the S40), not sure about the older stuff though if you are talking seperate coil implementation.
ah ha, cheers fella, hadnt thought that one thru![Wall](https://passionford.com/forum/images/smilies/wall.gif)
Will Holman from PPC got Dave Walker to alter an emerald unit to run 5 coils for his audi lump, and most of the ecus state 4, 6 or 8 cylinder engines.
I guess with a dizzy it doesnt matter, it only needs to know where the spark events occur (as opposed to needing 5 drivers for the coils..)
I wonder if the software in something like gotech would allow you to put in 5 sparks per cycle..
(musing while at work with about half a brain, probably being really stupid)
Mark
Emerald can also run 2 cylinder as well, as Dave's(emerald) old Norton is being converted to run this with fuel injection, with no dizzy as doesn't need it, same as cars.
Biscuit also has Emerald and FI on his old MG, working wonders, think he has dizzyless as well,(biscuit works for emarald).
John, who works at Emerald has it on a interesting duratec 2.3 engined reliant kitten at 230bhp!!
it seems goig back over them that most will, emerald sorted it for will hollman from ppc, dont know if these are for sale yet.
Megasquirt will do it, but info on which kit you need is sketchy. they sell for 335 quid built, tested with a wiring tail in this country tho.
cheers for all the advice guys, nothing worse than being armed with half the info
Resident Wrestling Legend
i was going to go with what rod was offering as he said it would run 5 pots
it's got the coil on plug set up x 5
but the more pressing problem is that apparently the ecu on the st lump sits in the air flow so i can't remove it even if it's redundant as otherwise ther eis a big hole and the diference in the air flow causes problems
then the sump isn't suited to north/south applications as th ebit that needs to be cut out has the oil drains bolted to it via some pipework and some holes in the sump![Wall](https://passionford.com/forum/images/smilies/wall.gif)
i'm sure i'll make it all work, i just need to figure out what it all does first![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
sorry to jump into your thread and hijack it
Bloody hell simon, you doin more undercover work then!
i have twigged that tabetha posts about emerald a bit! but just thought it was soemone who knew dave walker. lol
PS: TABETHA. If you ARE Karl of emerald fame... thanks for warrenty-ing my tacho driver!
the new one works no problems what-so-ever! lol
gotec can run on 5 pot engines we have done audi 5 pots and volvo-st 225 no problems
theycan also work the fly by wile witch is on most of the newer 5pots
does gotech do boost control out of interest?
Nothing fancy, I was a cap at 20psi, building a few psi at very high rpm as the VE drops off with the aim of holding 300ftlbs from 3500 - 7k.
For all you dickheads, Karl does not do forums due to peeps like you, I am in no way connected to emerald as ROOSIE off here and COZMEISTER can attest, as can Mike R as well as others, hopefully you will beleive some of these, but if not from the great god of cossie's I doubt it.
I give my reasons for not liking the std set up, this is a PUBLIC forum, unbeleivably it has members of the public on here, who may or may not have different opinions to your own.
Please feel free NOT to read any of my comments if you so please, I don't give a toss, and will continue to say what I feel appropriate.
I am ONLY staying here to annoy people who have a different opinion.
Why not PM the peeps mentioned, they will soon confirm I am NOT Karl, christ the so called good people on here can't even use the emerald system properly(with regard to live update), I can do it, so anyone else who has a brain should be able to as I don't do computers at all.
As they say RTFM.
As they say RTFM.
As they say RTFM.
As they say RTFM.
If so, TELL!
It would make it SO much easier to use if we all knew how to do this!
Ive R'd the FM and it doesnt say it in there anywhere I could see!
Please point me at which page of the FM to R again and I will do so.
As they say RTFM.
As they say RTFM.
or has that changed?
ok, carry on, someone was going to give me a price on a loomed up gotec
You know how to make the emerald do live update without having to press a ridiculous sequence of keys after each update?
If so, TELL!
If so, TELL!
It wont do it chip.. Tabetha is full of it
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Tabetha just wants to make it look like he knows a thing or two..
PS: Tabetha. as for calling me a dickhead
