Brake fluid recirculation valve
Hi,
Has any one got a diagram showing how to plumb a brake fluid recirculation valve in?
Thanks in advance.
Bri
Thanks in advance.
Bri
Up for the proper hardcore race/rally drivers on here,which I ain't!!!Or you could e mail someone like AP and ask them or whoever made the part.Regards,Micky
dont have a diagram but the out goes to a tee to feed the calipers,the return from the calipers goes to a tee then back to the unit and the in is from the master cylinder,the system is bleed from the nipple on top of the unit,the calipers you use need two connections
Sorry chaps haven't got any pics, the brakes are AP CP5820 and they came with a recirculation valve setup so have been used with that sort of a system in the past.
I think I'll just use them in a standard arrangement but would be nice to use all the system I have.
Brian
Brian
