what have i done
sara
what have i done
took my car out for a raggin last nite and now it sounds like its runnig on 3 cylinders
if i pull off lead number 4 the revs do not drop and the lead and plug is are sparkin fine
what damage have i done to my baby please help
Well what i'd do sara is remove ze plug in question and have a look to see if you have destroyed it or to see if its covered in petrol/oil. If it seems fine then a compression test will tell ya if ya headgsket,piston or valve has died
Let us know how ya get on ok
It means you have either holed a piston which is very likely because No 4 is the Norm or a oil ring has callapsed or the headgasket has gone near an oil way.What you need to do now is take the head off and see what it actually is.The head has to come off anyway,Not looking good i'm afraid
You can just repace the one if it hasn't damaged anything,i've repaced one before with no probs.
you know you shouldn't of caned it so why do it?? you'll learn the hard way unfortunately
U can replace 1 but u have to make sure they are all balances 2gether etc which is y alot of ppl reccomend replacing all 4. What its worth doin is cleaning up the plug and re-gaping it then run it without the injector connected (the wire to it not the actual injector ) cos its probably flooded by now anyway. Once u done that put the plug back in and give it a go!!
DEYTUKURJERBS
#1 in Spelling Club
Originally Posted by sara
the whole engine is 3 months old mate it wasnt setup and i shouldnt have been cainin it
Pull the head off and have a look.
Chances are if its a piston or something gone then the whole engine will need to be stripped down again
sara
_________________
not really what i wanted to hear mate tbh
lol
_________________
lol
sara
because the engine was swapped from one car to another and its had a few extra bits added and im still waitin for my bigger turbo to be fitted and was goin to get it all set up then
