changing a rocker cover
Old Nov 5, 2004 | 01:58 PM
steve rs's Avatar
steve rs
Default changing a rocker cover
ive got to change my rocker cover at the weekend do you just place the rubber cam seals in or do you need to put some sealer on them?
Old Nov 5, 2004 | 02:00 PM
Dilly's Avatar
Dilly
didn't change mine last time i had the rocker cover off. use some sealer where they meet the gasket
Old Nov 5, 2004 | 02:01 PM
St3V3_C's Avatar
St3V3_C
I put some sealer on, but don't go nuts - you don't want big pieces going inside the engine.
Blue hylomar or proper silicone sealant for bathrooms
frog's Avatar
frog
0-60 in 17 seconds (eek)
Dip the ends of the half moons in blue hylomar or something similar, don't over do it, you only really need a small amount.
Change rocker cover gasket and fanny's your aunt
Old Nov 5, 2004 | 02:03 PM
steve rs's Avatar
steve rs
ok ill try and get some will it matter if i don't put that on?
Old Nov 5, 2004 | 02:24 PM
Andreas's Avatar
Andreas
Yes, it will mostly likely leak oil if you dont add some hylomar or similar to the end of the halfmoon seals. Dead easy job just be careful to line up the gasket straight so you dont shear it with the bolts.
BRAMMER
15
Sep 14, 2015 08:52 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
Chopshop85
Sep 12, 2015 06:42 PM
marky_g
Sep 12, 2015 04:26 PM
rog
Sep 4, 2015 07:24 AM
