FPR on a rover inlet on ZT engine
Right i have been looking for a way to retain the origional fuel rail for the rover inlet and fit a fuel pressure regulator to it as the rover item does not look adjustable.
i have found an FSE power boost valve, i know they are all hype in most cases but if it means i can have the pressure adjusted to what i require then so be it, to fir the later type plastic fuel rail as i have for the rover inlet so that is a start, but was just wandering had anyone else used on of these as if there are other options then may save me a few £
And no i cant fit the fiesta regulator as it doesnt fit to the bolt holes in the rail and if i drill and tap it it will split the rail.
is he using the plastic rail?
only way i could poss see it going on is by having a spacer plate machined so that it would in effect twist the regularot rod slightly so that you sould bolt the plate to the rail and then a regulator to the plate. But that plate for the complexity of it would work out more than an FSE power boost valve prob
if you could please try and get a pic that would be a massive help mate as it would save me £80.
bit far for me to come TBH mate as im from north shropshire! :'(
literally just drill and tap the fiesta fpr on how the rover one comes off, i think the holes are closer together on the fiester on from what i remember but if you get the right size screws you shouldn't have a problem
big_Rad
15-09-2017 09:36 AM
