anyone run 6.8:1 compression?
Old Aug 11, 2008 | 06:41 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default anyone run 6.8:1 compression?
is this too low compression for a cossie, seen a set of pistons with this comp ratio just wondered if this cr is ok for 430bhp,t4,Ported head etc
Old Aug 11, 2008 | 06:43 PM
BigErn's Avatar
BigErn
Lawnsys is down at 6.9:1 on greys and T34@36psi and seems to do well
Old Aug 11, 2008 | 06:44 PM
Rs1's Avatar
Rs1
6.8 is ok...........as is 7, 7.2, 7.5, 8.0, 8.5 and possibly even 9.
Old Aug 11, 2008 | 06:46 PM
rapidcossie's Avatar
rapidcossie
Im down there somewhere and have the fastest saf after Rod's.
Old Aug 11, 2008 | 06:47 PM
Roosie's Avatar
Roosie
suppose you have to make it up with loads of boost!
Old Aug 11, 2008 | 06:50 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
but you can, safely. lots of ignition too.
properly low, but as long as you dont fuck things up with big cams, it seems to work just fine.
Old Aug 11, 2008 | 06:52 PM
rapidcossie
Mines run 2 bar now and big cams and doesnt seem to be short on power!
Old Aug 11, 2008 | 07:10 PM
peteh's Avatar
peteh
Danny b ran um in his old saph!
0-60 3.92, 12 sec quater (probably due to the rear end though, lol)
EDIT - think he rans BD16's and only 21psi.
Old Aug 11, 2008 | 07:15 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
your cams arnt long duration are they?
Old Aug 12, 2008 | 06:16 PM
NEIL A's Avatar
NEIL A
I went down from 7.2:1 and dont notice any change in the way the car drives off boost.
Old Aug 12, 2008 | 06:17 PM
rapidcossie
what do you class as long?
Old Aug 12, 2008 | 06:21 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
well whats your duration?
Old Aug 12, 2008 | 06:22 PM
rapidcossie
Think they are 265's
Old Aug 12, 2008 | 06:23 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
that is quite wild actually for a turbo car, but spools well, fair play
Old Aug 12, 2008 | 06:25 PM
rapidcossie
Alot of things on my car are specced for top end power but we still manage to get good bottom end too, just dont ask me how?
Old Aug 12, 2008 | 06:29 PM
NEIL A's Avatar
NEIL A
Where is your car making peak power now Euan think mine is 7800 ?
Old Aug 12, 2008 | 06:30 PM
rapidcossie
it makes about the same at 7500 as it does at 8000 now.
Old Aug 12, 2008 | 06:32 PM
NEIL A's Avatar
NEIL A
Cool mine is still going up at 7800 then levels i think but still more to do on responce,think the head might be flowing too well
Old Aug 12, 2008 | 06:34 PM
rapidcossie
Originally Posted by NEIL A
Cool mine is still going up near 8K i think but still more to do on responce,think the head might be flowing too well
leave it with Alan over the winter and see how how much he can squeeze out of it.
Old Aug 12, 2008 | 09:28 PM
col cos1's Avatar
col cos1
i run 6.9.1,t4 twin bd 14s at 30 psi and its a dog under 4k
Old Aug 12, 2008 | 09:41 PM
glancy2081's Avatar
glancy2081
that could change once its been mapped col
Old Aug 12, 2008 | 09:44 PM
col cos1's Avatar
col cos1
hopefully glancy,hope the new head inlet etc make a diffrence aswell
they were working on it today,so hopefully mapping starting soon
Old Sep 1, 2008 | 11:55 AM
Roosie's Avatar
Roosie
has it been mapped yet.
keep looking at Euans JE pistons for sale
Old Sep 1, 2008 | 07:05 PM
col cos1's Avatar
col cos1
yip its done 419@wheels on full boost at just over 3.5k im led to believe
Old Sep 1, 2008 | 07:41 PM
Rick's Avatar
Rick
At what what lift? A std RST cam is 270 degrees at 0.1mm lift. You have to be careful when comparing figures, without the lift it's meaningless.
Old Sep 1, 2008 | 07:48 PM
rapidcossie
.399mm valve lift on my cams.
TPM961
Jan 15, 2018 10:50 AM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
