Anyone used pulsar pistons for a ZVH?
A mate recently bought a a complete ZVH with steel internals & the bloke gave him a brand new set of nissan pular gti-r pistons on standard zetec rods with it. He said he was going to use them before he went the down steel route.
I know only really of the calibra turbo pistons being used & even a few running celica gt-4 pistons but never these!
![](http://img.photobucket.com/albums/v286/thersman/pistons008.jpg)
Colossal Pervert
It's very similar to a Supra piston.. 86mm bore.. 22mm pin.. ~32mm compression height..
It will fit in a zetec.. not sure if the skirt will hit the oil squirters though, only one way to find out!
The compression ratio wont be very low - it's only 1mm shorter compression height than a standard zetec piston (compared to 3mm shorter with a calibra turbo piston)..
Probably be fine for a ZVH though due to the larger combustion chamber? Best to dummy build and measure to know what's what. Not sure i'd be happy with boring out the standard rod to 22mm though.. That's 1.37mm oversize.
Colossal Pervert
Colossal Pervert
deathrider666
28-09-2015 06:12 PM
