is this a cosworth t5 gearbox mount...?
14000+ post superhero
my bmw has a mix and match of parts cut and welded together and this gearbox mount rubber has seperated from the metal so i dont know where to go for a replacement, bmw or ford.
is this a t5 mount?
is this a t5 mount?
will do, my cameras fooked so i used my mobile. the top bit fits into the square hole in the bottom bit .....photo to follow.....
my mounting cradle is a welded up bodge job and the top part is alloy but very dirty, theres also an alloy block spacer between the mount and the cradle. theres a big round disc that bolts up through the bottom part
dam, my pics arent resizing.......
the top part is alloy with a rubber bush....and thats seperated from the lower part....
closer inspection has revealed a part number of 85hf-6068-bac and 60075 and a ford logo on the rubber bush so its definately ford . it looks different to the ones posted above .....?
van_dogg_pavvy
03-03-2016 09:30 AM
wheelwizardrefurbs
04-08-2015 06:23 PM
