Quick question !
Old Aug 6, 2008 | 02:28 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Default Quick question !
What would it do if the 2 outter wires on the tps had been changed to use a 2wd item & then you fitted a 4wd one & not swapped the wire back cos you forgot ?? Would if flame alot ??
L8 ecu on a 4wd loom
jb
P.s. I know to use the other tps you have to swap the wire but never understood why ?? Guessin the range works oppersite for each sensor ??
Old Aug 6, 2008 | 02:37 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
I didnt think it would run at all...well not rev up anyway.....although I stand to be corrected!!!
Old Aug 6, 2008 | 02:56 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Well mine does
The original engine was on 2wd tps (red one TF01 I think ?) & when I got this engine it was on 4wd tps (black/grey one TF09 i think ?) and only jus realised the wire were swapped for the 2wd tps.
How do I check if they are the right way round ??
jb
P.s. cheers for the reply
Old Aug 6, 2008 | 02:59 PM
Stu @ M Developments's Avatar
PassionFords Creator
If teh signal is inverted it will run leaner than wanted at low throttle positions and vica versa.
Old Aug 6, 2008 | 03:01 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Cheers Stu, much appreciated !!
So what colour wires should go where ?? Haven't actually looked yet.
jb
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
