Tuners.....
#42
Originally Posted by Bosch Man
Phil..
What exactly do you call "Tweaking a base map"
And what is your definition of mapping? Im interested to know.
Well as i am no mapper my definition is not what i am doin to my car which is using a base map and changing the ignition/fuelling at certain points to get the best out of my engine according to the tools i am using...also setting boost map up from scratch etc etc.
So my actual defintition is someone who Mike just described,having the ability to write a map from scratch...which i could not do and feel alot of tuners could not do.
Are you talking about that actual software that allows you to input the figures? The bit you actually See as your "mapping software"
Or are you talking about knowing what fuel and spark figures to put in the control map itself that contains only zeros?
IE: If you put in;
12degrees idle, 30degrees part load, 15 degrees low boost 14 degrees high boost for a spark base, then put 2ms idle, 3ms cruise, 9 ms low boost 17 ms high boost, + 42% fuel adder for around 20Deg C retarding down to 5% adder at around 63 deg c to get a fuel map base. Sort your phasing degrees out for cranking with around 4 rpm increasing split points and then you know a 9:1 engine with 300CC injectors at 3.5bar should at least start and run?
If thats what you mean, i could probably do that in my sleep, in fact, ive had greater and more complex ideas than the above for lambda control in my sleeping hours and implemented them during the day
If its the software side your talking about, im not a mapper either according to your definition
**Ive decided to add a disclaimer to say teh above figures are an example and if your new map melts your engine, its not my fault...roflol You know what its like for folk taking things wayyy too seriously round here
#43
Originally Posted by Nicole
Phil, i guess you think that mapping from scratch involves writing the software itself, when that is in fact a software programmers job.
A software programmer can no more map a high performance engine than a mapper can write high performance software
Damn... thats such an easier way to say what i just said
Im impressed
#46
IE: If you put in;
Thats a proper mapper ...i am just a Tweaker...
#47
I think I deserve a medal for the restraint I have shown here
Clearly I was supposed to bite on this one
But I just sat back and watched everyone else administer some
Thanks guys
Thanks guys
#48
Thanks guys
Thanks guys
Me too......I saw this thread for exactly what it is the moment it was posted
#54
Love that second sentence:
"As these people can only really be deemed at the top of the tree"
Deemed by WHO ????????? And the top of WHOSE tree??????????
PMSL..........sheer provocitive arrogance
#56
Yet another post that backfires on the paranoid
I am more sincere than you could ever be!
#57
Caraholic
Doug,
I (who like Phil) agree with what you posted above .
It appeared to me that Phil came on wanting to imply that it his his "current"* adviser who is the only one capable of doing all the things that he stated:
1. Design / build engine.
2. Map engine.
3. Set records.
He the was well and truely by all and sundry .
*Until he does / says something to upset Phil and Phil moves on to his next "victim" .
2. Map engine.
3. Set records.
#60
Lee,
U must give me some tips, as i just fall straight into the trap LOL
#62
This post was purely asking wether any other record holders had the same criteria from there tuners....nowt provocative about that!
So jim you decieded to go against our aggreement?
#63
WHY THE FUCK HAS PORKIE GOT A BEARING ON THIS POST OR DOUG
They are both nobodys with lots of cash in the car world
NOBODYS being not pros like myself and the majority of people here.
#65
i still mean it
#67
Phil, i don't class Porkie as a nobody he is actually a good freind of mine.
He does have some bearing on this post as he has used diffrent tuners.
What difference does it make if he has money or not? You do talk rubbish Phil
#69
I class him as a nobody...why is that wrong to say I never met him and he will never be a mate.....Your knickers are twisting
As to this post....he claimed it was for him to bite at..inwhich he could not be further from the truth as he only drives the finished article..well half drives as its a joint car i understand.....so i say again he has no bearing on this post...
#71
Surely its the end result that you get for your car that matters, not if one specific person can design the map from the start, tweak it, build the engine and keep ya happy.
I think if someone is using another person to help and the result is better, why does it matter?
#80
Jimmy......i take all your insults with a pinch of salt....as i remember the PM you once gave me saying you wanted me to be banned so you can be numero uno That was a compliment and every post you make to me since my return has portrayed jealousy.....but hey dont be down hearted as you have the award for best Guy Fawkes impersonation
