Mad Rod back at the dyno today
Old 04-08-2008, 05:48 PM
  #121
Staffi
Staffi's Avatar
Originally Posted by cozzymatt
weigh the lot in for scrap!!!!!
  #122
Chip
*** Sierra RS Custard ***
Chip's Avatar
Well every head lifts to a certain extent, its just a case of how far.
I wasnt in the dyno cell with a half thou feeler gauge trying to slide it under so cant say if that happened or not, but Id imagine its lifted enough to release some clamping pressure.
Yes its long studded on mounty studs I believe.
It wasnt past peak BHP when it spat it, in fact it was only at 7K rpm
It was only very brief dyno pulls, so no time to get a meaningful EGT reading, mark will do those in the car instead.
Originally Posted by dumped
Is the head lifting? what headbolts is it on, I guess ts a 10 bolt WRC job but on mountune stud/nut kit?
Why is it spitting its gasket past peak hp/rpm or is it?
Hope you get to the bottom of it so that you can run it at full beans and timing. Nice to see the block is happy at these levels after the turkish one spat the dummy.
At 14 degrees advance on a big cossie engine there is no risk of burning exhaust valves out in short mileage? What sort of EGTs were you seeing?
Good luck on any revisions and thanks for putting it up.
Old 04-08-2008, 05:50 PM
  #123
cossie604
cossie604's Avatar
check out my website for headgasket prices
Gutted for all involved though
As said previous, what are the Norweigen boys using for headgaskets in their high comp YB lumps?
Old 04-08-2008, 05:51 PM
  #124
Chip
Chip's Avatar
It varies, I dont know of any of them making 638lbft of torque though to be fair, which is arguably more important than the BHP figures involved.
Old 04-08-2008, 05:52 PM
  #125
rapidcossie
rapidcossie's Avatar
I have had major work done along the lines on keeping the head on the block but Im sure Rods block will have had the same done.
Old 04-08-2008, 05:56 PM
  #126
Chip
Chip's Avatar
What major work do you mean? Or are you just on about the longstud conversion more or less everyone tends to do on relatively high power YB's? That doesnt really seem very major to me, but I guess we all have different impressions of what a basic or major mod is.
As far as im aware, other than the longstuds, nothing has been done to the block itself on Rod's to try and promote head gasket seal.
  #127
cossie604
cossie604's Avatar
Cant be argued thats a huge torque figure for such a small engine...cant some one like Reinze or any other big gasket manufacturer make a one off gasket to suit? I know it would be expensive as a one off from such a large company but end of the day it needs something reliable...something that the current off the shelf jobbies dont seem to be specced up to doing.
Old 04-08-2008, 05:58 PM
  #128
cossie604
cossie604's Avatar
Off topic slightly but has anyone tried getting these sort of figures out of a millington set up?
  #129
rapidcossie
Not just long studs conversion but how the studs actually connect to the block.
  #130
Chip
Chip's Avatar
The waterways in the block (ie their size and placement) has a significant limiting factor in terms of where you can put strength into a head gasket, so its not just as simple as redesigning the gasket itself, the two gasket types that have both failed now were both designed specifically with mega strength in mind dont forget!
Old 04-08-2008, 06:02 PM
  #131
COCHYN
COCHYN's Avatar
Some impressive stuff there. Any idea what the 1/4 mile might be with this new engine?
Old 04-08-2008, 06:03 PM
  #132
cossie604
cossie604's Avatar
Not great at present
You read the whole topic or just the start chap??
Old 04-08-2008, 06:04 PM
  #133
Chip
Chip's Avatar
In what car? Rods? I doubt he'll be running any, its not what he is into, car would need significant other changes to be any quicker on this engine than its last one.
Old 04-08-2008, 06:06 PM
  #134
RS 5tu
RS 5tu's Avatar
Any one know what power he is hoping for??
  #135
Chip
Chip's Avatar
Might be worth reading the topic before replying?
Old 04-08-2008, 06:07 PM
  #136
Mark Shead
Mark Shead's Avatar
Yes It looks like a head gasket problem, This time it has spat out the gasket in the front right in the middle of the block,
This time we used much less ignition advance on race fuel and the problem happend later in the rpm band than before,
I will be looking at it tomorrow to see the problem but it looks like the change in head gasket type could have been a backwards step, No going to blame or name the gasket until more checks have been made.
Mark
Old 04-08-2008, 06:09 PM
  #137
Mark Shead
Mark Shead's Avatar
Originally Posted by RickyLee53
Isn't this the 3rd failure in 3 dyno attempts? Surely they must be thinking about calling it a day. If it can't manage the dyno session it's going to be hard to make it reliable enough to do top speed run's.
Hope you get it sorted and make the race.
You cant make a omelette without breaking some eggs and so far only 2 eggs have broken and not to costly either.
Mark
Old 04-08-2008, 06:12 PM
  #138
Alg1k
Alg1k's Avatar
A copper gasket would not have the strength unless it was
backed up by something, wire ringing of cyl head and block
One inside the other and a crommolly fire ring stepped into copper on the gasket,
The wrc is never going to cope with these pressures
  #139
Chip
Chip's Avatar
  #140
Mark Shead
Mark Shead's Avatar
Originally Posted by Stavros
shite news going so well as well.
maybe its not ignition timing afterall then.
personally its that compression ratio im scared of, but mark is far cleverer than me.
The compression is not a problem, I still have plenty of igntion still in it, Going from 7.9-1 to 8.5-1 only reduced the timing by 4gd.
Mark
Old 04-08-2008, 06:14 PM
  #141
Doby
Doby's Avatar
sad news mark maybe give JG a call and ask how he keeps his head gaskets intact???No shame in asking them.
I take its the boost that is lifting the head slightly causing the failures.
Old 04-08-2008, 06:16 PM
  #142
Chip
Chip's Avatar
No its not boost lifting it as such, its cylinder pressures lifting it, boost is only one of many things that effect cylinder pressures, timing in particular.
It was running no more boost (well within 1 psi) at any point on the new inlet than it was on the old one, it made a lot more power though, and im sure had a similiar percentage rise in cylinder pressures, and thats what has seemingly killed it.
Old 04-08-2008, 06:18 PM
  #143
rapidcossie
High cylinder pressure are part in parcel with the high torqoue so there is no getting away from it?
Old 04-08-2008, 06:19 PM
  #144
Chip
Chip's Avatar
Its not that simple a relationship.
Perfectly possible to increase torque at the same time as decreasing peak cylinder pressures.
Old 04-08-2008, 06:22 PM
  #145
Alg1k
Alg1k's Avatar
Perhaps you should map it Chip,
Old 04-08-2008, 06:24 PM
  #146
Chip
Chip's Avatar
I cant map as well as mark, so that sounds like a bad idea to me.
Old 04-08-2008, 06:25 PM
  #147
rapidcossie
I thought you needed the high pressure to make the high torque?
If you drop pressure you drop torque?
Im no expert but thats how I understood it.
  #148
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
Just got home.
Feel sorry for Rod and Mark. The figures on pump fuel are just insane. Imagine feeling that on the road Shame the gasket let go at 791bhp. Mark will sort it. WRC h/g to be fitted i reckon
Old 04-08-2008, 06:26 PM
  #149
Alg1k
Alg1k's Avatar
LOL
Im sure Mark will sort it
Old 04-08-2008, 06:27 PM
  #150
Chip
Chip's Avatar
Torque is a measure of the sum of the cylinder pressure multiplied by the leverage of the crank at each point during the cycle effectively.
To simplify it excessively, think of it as a measure of average cylinder pressure.
You can have a lower peak pressure and still a higher average pressure, if you apply the pressure for longer.
Old 04-08-2008, 06:28 PM
  #151
CossieRich
CossieRich's Avatar
Chip,
you left your sat nav in my car. You getting forgetful or something mate?
  #152
rapidcossie
Starting to lose me a bit Chip.
How would you apply the pressure for longer?
longer stroke engine?
Old 04-08-2008, 06:29 PM
  #153
rapidcossie
Originally Posted by CossieRich
Chip,
stick it on ebay!
  #154
Steven_RW
Steven_RW's Avatar
Te he to that. Sure chip will take it in his stride (the cheeky comment not the mapping!)
Shame to hear it went pop again.
Really hope you guys find a suitable solution.
Out of interest - would it not have been running more lb/ft on the previous engine when nitrous was used than it is currently on the dyno with no nitro?
RW
  #155
Chip
Chip's Avatar
Chip,
arse, need that tonight as well as supposed to be going to a BBQ and spanish's and got no hope of finding it without satnav as I dont know that bit of london at all, doh!
Old 04-08-2008, 06:30 PM
  #156
sbd16v
sbd16v's Avatar
changing the cam timing and stroke would be my guess
  #157
trevCOSS
trevCOSS's Avatar
surely there is a limit to how long you can apply said pressure and when that limit is reached more pressure is the way to make more torque?
  #158
Chip
Chip's Avatar
I did a detailed set of diagrams on here previously mate
Old 04-08-2008, 06:35 PM
  #159
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
The 2 graphs taken today.
The pump map was on the RS500 inlet & so theres more to come from this im sure. This was a conservative map just as Mark wanted.
The first race fuel (109ron) figures saw 758bhp again with boost & ignition on the conservative side, fairly clear that the RS500 inlet had found its limits.
The inlet was changed & saw a 40bhp gain with 30torque on race.
This was the second session of our R&D being done in public & overall im happy with the response, it seems to work, only a few saddo's being negative. With the gains seen today Mark is happy with the engine spec & so sealing the gasket is now the priority, before you ask, yes there will be a part 3 to this saga in the not to distant future, with 750 pump & 800 race the targets which now seem very attainable.
Cheers Rod
If the head gasket is all thats wrong a WRC will be fitted & the car used on the pump fuel map at Fighting Torque. Pump fuel should be 750+ on the new plenum & with our Nitrous adding circa 250bhp we wont be short of Power.
Old 04-08-2008, 06:39 PM
  #160
MikeR
MikeR's Avatar
Sorry to hear about this Rod but all the respect for being open about it in public,
Mike
Quick Reply: Mad Rod back at the dyno today
