Pics of WRC top mounts required please
After the BTTT of the R&B "prices are on my website" alloy adjustable top mounts thread I'm interested to see some pictures of the works mounts, fitted and off the car woudl be good and even better if someone could take the time to explain how they are fitted please.
Thanks
Thanks
I was thinking Ian may be able to help.
I appreciate everyones concern over these mounts you have Mike but tbh the works ones look to fit the same imo and I'm guessing Ford Motorsport got it right.
I'll leave you to dig through pics whilst i'm on my dial up connection
How much are your mounts again Mike ?
Jonny,
The turrets are constructed on the bench, with captive nuts tigged to the underside then the whole turret assembley is welded to the car.....
Like all things on a well designed suspension arrangement, when it is worked in correctly it makes a massive difference.
The modification would be fine on a track car, overkill perhaps but it'd work well...at the end of the day most track cars dont need the level of suspension travel a rally needs as you're not subjecting the car to undulating and changeable surfaces, long suspension travel ensures a car rides the bumps well without hitting the bump
-stops and ensures you have good control over the whole range ie high and low speed compression as well as re-bound....
Even some of the cheaper kits available now offer superior control over those parameters so correctly tuned should give a driver extra speed and quicker lap times....
I used a pair of WRC top mount bearings on my car , i got sick of the crappy TAS style eccentric bearings falling apart so i milled the centre out of the flat aloy plate and let the WRC parts into them with a set of top hats to space it up , seems to work ok .
![](http://img.photobucket.com/albums/0703/TonyRyan/aw00006e.jpg)
As for how much , the risers are probably about £500 the pair , plus the welding , the WRC bearings are about £800 a pair ( from memory ) plus any sundries that is .
The additional height also allows the Tarmac spec cars to run low enough without running out damper travel , a problem that the GpA bodies induce !
they are not exact copies, same principle and same geometry, but i cant have them madw unless im haveing four sets done at a atime, and thats just for the plates, the bearing carriers I cant do, the tube that the bearing sits in i did myself, and no time to do anymore imafraid. I only have one set left and they are my spares.
the pukka WRC items do come up for sale on ebay, that last top mount i saw without bearing carrier went for about £70 iirc, so used price for a full top mount will be about £200 ish a corner i reckon.
lol - for £800 a set i would find the time to remake them !!![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
try ringing dewitts, they will have them.
dewitts bought all the ford motorsport stuff leftover from the wrc projects (and alot more besides) they have enough stuff to build approx 3 new WRC escorts, and they re-produce the obsolete stuff for them, but be warned, you are going to be paying WRC prices
its a bit like 'group a' only a lot more exotic ![](https://passionford.com/forum/images/smilies/shocked.gif)
http://dewitts.co.uk/
jessie_rs
11
03-06-2019 04:57 PM
matman
09-09-2015 05:45 PM
Anutternutter
21-08-2015 06:07 PM
