BHP vs Torque?
Old 25-07-2008, 11:42 AM
  #41
JohnnyB
JohnnyB's Avatar
See above chip is not a thick cunt
Old 25-07-2008, 11:46 AM
  #42
AlexF
AlexF's Avatar
Originally Posted by Chip
Thats the only time really that torque IS more important than horsepower IMHO, but once you are moving, you then need the horsepower to accelerate.
WHAT?
to accelerate you need power?????
NOOOOO
Force = mass x acceleration
so you have a car of mass x and you are accelerating at rate y - from somwhere you need a force!!
Torque = force x distance
you need torque to accelerate and nothing else!!!
The result of you having accelerated ie the car is going faster is POWER.
Old 25-07-2008, 11:51 AM
  #43
Chip
*** Sierra RS Custard ***
Chip's Avatar
Originally Posted by AlexF
WHAT?
NOOOOO
No alex, you are COMPELTELY missing my point.
Lets say you have 500lbft of torque, but only 200bhp for example.
You will hook up at 1000rpm and by 2000rpm you will have to change gear!
You CANT accelerate hard up the strip without big horsepower, end of, no exceptions!
  #44
lead_foot
is awesome
lead_foot's Avatar
As far as I see it:
Torque makes it feel fast
Power makes it actually fast.
Good analogy or a load of shite?
Old 25-07-2008, 11:53 AM
  #45
Chip
Chip's Avatar
Originally Posted by lead_foot
As far as I see it:
Not really, as you can have less torque and more power, and it will feel faster IF you are in the right gear.
The only reason people think torque matters so much is that they are scared of their gearbox
Old 25-07-2008, 11:54 AM
  #46
Turbosystems
Super Moderator
Turbosystems's Avatar
bhp = torque x a constant x rpm
  #47
foreigneRS
Testing the future
foreigneRS's Avatar
if gearchanging were seamless and instant and you had no limit on the number of ratios, it wouldn't matter (until you get to the speed where drag = power and you can no longer accelerate)
Old 25-07-2008, 11:55 AM
  #48
AlexF
AlexF's Avatar
Chip,
I know what your saying just mucking around
But your ignoring gearboxes....
  #49
Chip
Chip's Avatar
utter rubbish, because everytime you change up a gear, the torque at the wheels (where it matters) drops massively!
  #50
Chip
Chip's Avatar
Chip,
No im not, im not ignoring anything at all, I understand the subject FULLY
The moment you change gear to get back in the power band, you have just REDUCED the amount of torque at the wheels.
Thats why you need the torque to continue up the rev range, which is what then results in more horsepower!
Old 25-07-2008, 11:56 AM
  #51
foreigneRS
Testing the future
foreigneRS's Avatar
torque at the wheels only drops massively if you have a massively different gear ratio
Old 25-07-2008, 11:57 AM
  #52
Chip
Chip's Avatar
Indeed, BHP is both torque AND rpm in one very useful combined figure.
1/5252 being the constant in the case of bhp and lbft of course.
Old 25-07-2008, 11:59 AM
  #53
Chip
Chip's Avatar
And if your gears are only 1% apart, you spend the whole time changing gears, and its STILL dropped massively by the time your speed has increased.
If you are doing 20mph when you change out of first gear on your low revving torquey motor with 500lbft, then by the time you get to 100mph you only have the same acceleration as you would in that first gear with a mere 100lbft if you had the revs to be able to stay in that gear, and you wouldnt have wasted time with lots of gear changes first!
Old 25-07-2008, 12:05 PM
  #54
foreigneRS
Testing the future
foreigneRS's Avatar
you wouldn't have lost any time changing gear
if you are comparing doing 100 mph in one gear with doing 100mph with many gears, then you are not talking about the same engine capacity
Old 25-07-2008, 12:08 PM
  #55
AlexF
AlexF's Avatar
Bingo...
You need torque all the time - low revs, high revs and medium revs
Old 25-07-2008, 12:09 PM
  #56
Turbosystems
Super Moderator
you are correct chip is not thick
  #57
Chip
Chip's Avatar
Unless you are talking CVT, in which case it does t technically class as a gear change, but as a gearing change, you will ALWAYS have "some" time to change gear on a manual box, so its a pointless statement you are trying to make.
Even more so because as the gearing changes, the torque at the wheels drops linearly, where as if you keep the torque constant up the rev range (different boost curve or whatever to do so) then it will accelerate linearly (bear in mind at the same time it will be resisted by air resistance etc though of course so your linear accelerative force wont equal linear acceleation, but that reduction is the same in both cases)
Thats not the case at all by definition, no one has mentioned capacity at all.
Old 25-07-2008, 12:10 PM
  #58
Chip
Chip's Avatar
Bingo...
Not true once you are moving, you only need it at high revs as thats the only place you will ever be in a race, well if you can drive anyway, lol
Old 25-07-2008, 12:15 PM
  #59
K-NINE
K-NINE's Avatar
Engine Transmission output torque (ft-lb):
Torque 1st 2nd 3rd 4th 5th
RPM (ft-lb) 3.54 2.13 1.36 1.03 0.72 <- gear ratio
1000 50 177 107 68 52 36
1500 65 230 138 88 67 47
2000 80 283 170 109 82 58
2500 92 326 196 125 95 66
3000 104 368 222 141 107 75
3500 114 404 243 155 117 82
4000 120 425 256 163 124 86
4500 125 443 266 170 129 90
5000 130 460 277 177 134 94
5500* 133 471 283 181 137 96
6000 130 460 277 177 134 94
6500* 122 432 260 166 126 88
7000 110 389 234 150 113 79
From a 2.0 ohc engine with a 5 speed box.
Old 25-07-2008, 12:22 PM
  #60
Chip
Chip's Avatar
Two simple questions for all.
Anyone with half a brain should be able to see the VERY obvious answers and that should hopefully just end this debate totally, lol
You have a car, it has a CVT gearbox, the revs will remain exactly the same at all times and the gearing will seamlessly vary, its a magical CVT box in that it can do any ratio you want, and it doesnt have any transmission loss to consider.
question 1:
Where on the power curve or torque curve will you set the RPM point the gearbox maintains, for maximum accelration and top speed, is it:
a) at peak torque
b) at peak power
c) where the power and the torque cross
question 2:
If all these engines weight the same etc, which will provide better acceleration AND a high top speed in our car (after the gearbox has been set to optimum for each one):
a) 1,000 lbft, 200bhp
b) 500 lbft, 300bhp
c) 250 lbft, 400bhp
Thankyou, please come again
Old 25-07-2008, 12:27 PM
  #61
Nick D
Nick D's Avatar
I'm confused
Old 25-07-2008, 12:28 PM
  #62
Chip
Chip's Avatar
Originally Posted by dunlop2008
I'm confused
How did someone so stupid ever end up with enough money to buy all your cool toys, are you a footballer?
Old 25-07-2008, 12:54 PM
  #63
AlexF
AlexF's Avatar
top top question
Old 25-07-2008, 01:13 PM
  #64
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
As far as I see it:
My car is fast & it acclerates cos of its flat Torque curve you are only on peak Power once in every gear. Seen dozens of torque less wonders struggle down brunters & not reach 180 telling everyone about their 600bhp no torque shite. Mine held the RWD Topspeed record down Brunters with 480bhp but with 500ft-lb torque.
Chip get back to IT leave this stuff to the likes of Colin Chapman.
Old 25-07-2008, 01:16 PM
  #65
Chip
Chip's Avatar
Rod your car was well fairly suited to your gearing at 180mph, with different gearing and 400lbft and 600bhp it WOULD be faster at brunters than with 480 and 500, and Colin Chapman (or even mark shead I suspect, lol) would agree with me on this one
If you are comparing two 500bhp engines, then the one with more torque is likely to have a flatter curve and hence be quicker, but a car with more power and less torque would beat you, thats how physics works.
And by having more power, I mean ACTUALLY having, not claiming, lol
Old 25-07-2008, 01:23 PM
  #66
Nick D
Nick D's Avatar
I wouldn't consider myself stupid lol
I had a very good start in life, and with a "bit" of hard work it payed off!
Started my company at the right time, and got my first 5 projects off my Dad.
Old 25-07-2008, 06:19 PM
  #67
K-NINE
K-NINE's Avatar
For road,torque is what you want,for racing you need BHP unless you are a restricted rally car LOL.
Simple way of explaining it really.
Old 25-07-2008, 06:27 PM
  #68
Stavros
DEYTUKURJERBS
Stavros's Avatar
depends what road you talking about and how you drive.
torque is lovely, but any less than about 400bhp isnt enough
Old 25-07-2008, 06:38 PM
  #69
K-NINE
K-NINE's Avatar
Of course,but a normal driver is better off with torque,me i want more torque than bhp on the road.
I have experience of this as i own a german car with more torque than bhp 516ft/lb to be precise,i also own an italian car with more bhp than torque,by far the easier nicer to drive is the german car with limitless power from 2000rpm,the other has to be driven hard which is a bind unless you are on a race track and flat out most of the time.
Old 25-07-2008, 07:18 PM
  #70
Mark V8
Mark V8's Avatar
The reason I'm sticking a 5 litre engine in my Escort is that small engines piss me off, perhaps I'm lazy but ringing the neck of a small engine to get the power of one that is under less strain for the same power level does not make much sense.
Mark
Old 25-07-2008, 07:48 PM
  #71
Fast Guy
Fast Guy's Avatar
Perhaps we should stop calling it BHP and refer to it purely as "revs * torque"
People wouldnt argue about what was better then!
But they might argue it's torque*revs/5252 (otherwise bhp would always be higher than torque,when in reality it never is below 5252rpm)
question 1:
a) at peak torque
b) at peak power
question 2:
b) 500 lbft, 300bhp
c) 250 lbft, 400bhp
Question 1 - I'd actually set it slightly above peak rpm to make use of the available power before it drops off too much.
Question2 - Top speed will be c)
Best acceleration would be a in theory be a), but you'll probably find it weighs well over 7.5tonnes and is limited to 56mph (1000lbft at 1050rpm that's a big engine, what's the rest of the power curve like?)
On the road b) would be the best all rounder as it has good midrange
On the track I'd probably fancy c) as it has good torque high up.
The simlpe answer to this is----
Most (highly tuned cars excepted) have max torque lower down in the rpm range say 3.5-4.5Krpm Max power can be from say 6200rpm upwards on 16V motors.
Take your car down the drag strip and do 2 runs.
Run1 change gear at your max torque rpm
Run2 Change gear at your max power rpm.
See which is quicker down the strip. I know which one I'll put my money on.
Where does any car make it's theoretical top speed? at the Max power rpm or max torque rpm? (still assuming optimum gearing for top speed)
Old 25-07-2008, 07:51 PM
  #72
K-NINE
K-NINE's Avatar
You should always change gear at max power RPM.
Old 25-07-2008, 09:42 PM
  #73
AlexF
AlexF's Avatar
Even mid bend
Old 25-07-2008, 10:03 PM
  #74
POPEYE
FAIRY CAKE
POPEYE's Avatar
I like the low down grunt of my car, makes 483 lb/ft
Revs quite well for a V8 i thought, got bloody long gearing though, does about 80/85mph in second. Wouldn't mind changing the rear diff to 3.9 or 4.11
Old 25-07-2008, 10:05 PM
  #75
COCHYN
COCHYN's Avatar
BHP sells cars, TORQUE makes them go
Old 25-07-2008, 10:36 PM
  #77
4x4
4x4's Avatar
ah ha thanx for that, thats summed it up a treat... Why chip and the others couldn't put their scenarios in such an easy way is beyond me... subject solved, thread closed, we can all go home
Old 25-07-2008, 10:41 PM
  #78
Chip
Chip's Avatar
Fastguy, totally incorrect answer to the second one.
C would be the highest top speed and C would be the fastest acceleration
Old 25-07-2008, 10:42 PM
  #79
Chip
Chip's Avatar
Other than the minor fact that what he put is of course total bollocks, but thats a small point as at least it was catchy and short
Old 25-07-2008, 10:50 PM
  #80
Chip
Chip's Avatar
utter utter bollocks.
Typically to maximise acceleration you change up shortly after peak power, if you change up at peak power, the revs will drop too far going into the next gear and you wont be back on it hard enough, so you rev past.
If you want to get slightly technical, you should plot the torque curve multiplied by the gearing out for each gear, and change just ever so slightly after they cross.
Typically its about 500-1000rpm past peak power, but that really is a huge generalisation of course.
Quick Reply: BHP vs Torque?
