Noisy tappets after high revs
Now I have never had problems with holding the car at high revs(over 7k) before but on the rollers on Thursday and on the road tonight I can actually hear what sounds like noisy tappets for a minute or so after a some spirited driving (160+
I know this is prob just the need to move to solid lifters but why is it doing now after all these years?
Oil temps are never above 90 even though it is very warm tonight.
Thoughts and ideas?
Thoughts and ideas?
My Cossie Ate My Money
over 1k but im unsure
you can hear them at the start of this vid
http://www.youtube.com/watch?v=_QMHRUWYitQ
SORRY FOR HIJACKING THIS THREAD BTW
![](https://passionford.com/forum/images/smilies/dors.gif)
Could be little ends starting to wear. My last one sounded very similar to that.
Can also hear a slight noise from maybe a tensioner or something too for a second.
Euan how long you been running with these lifters in mate?
Solids would be the way to go in your car I guess, anything that revs high and spends a lot of time up there will kill hydraulics fairly quickly.
Did Someone Mention TUV
SORRY FOR HIJACKING THIS THREAD BTW![](https://passionford.com/forum/images/smilies/dors.gif)
Thoughts and ideas?
Thoughts and ideas?
Solid is the only way to go IMO. We've had to do it on all the engines that are rev'in high. (non cossy)
i use silkolene pro s 10w-50
the car had a brand new cambelt and tensioner recently
sorry again for hijacking
i found my 2wd did this and i traced the cause back to the oil pump gasket was flawed and sucking in air ....
which in turn causes air in said tappets instead of oil lol...
i now always use some gasket goo along with gasket just to aid the sealing
regards
regards
i used to get this on the rally car after a long stage, the things i found out through trial and error - do not use synthetic oils, only use good quality mineral oil and i changed it after every event - about 60 flat out stage miles and maybe 100 or so road miles, and change the filter with every change, this seamed to stop it, though i did go to solid lifter eventually, as will the new engine be on solids.
07-10-2015 12:56 PM
