computer adapter leads for engine management?
Old Jul 21, 2008 | 04:46 PM
rst in breaking's Avatar
rst in breaking
Default computer adapter leads for engine management?
i bought a lead to adapt the emerald pc loom to turn it into a usb fitting, the adapter software is uploaded but the computer doesnt pick up the ecu with the ignition on. my mate said he had the same problem so he bought a really basic old school laptop with origonal screw in type plug which works it fine? he said he's known people to have problems with these leads and just wondering if anyone else has? cheers
Old Jul 21, 2008 | 04:50 PM
Jim Galbally's Avatar
Jim Galbally
dont use the USB adapters, most dont work properly unfortunately
get yourself a PCMCIA (PC CARD) one and you should have zero problems.
Old Jul 21, 2008 | 04:51 PM
Jim Galbally
just looked on ebay and the first few results are all <£10 and look like cheap shit from hong kong. dunno if theyre any good or not
Old Jul 21, 2008 | 05:03 PM
rst in breaking
cheers mate, just had a look, what does it actually plug into though as it looks like a drive im unfimiluar with i have the 9 pin emerald lead that needs to go to either usb or the video port which the video port ive been told is no good?
Old Jul 21, 2008 | 05:39 PM
Jim Galbally
its a 9 pin serial port, the connector is called an rs232. refered to as a COM port also. its what we used to use before the days of USB.
unfortunately most laptops nowadays dont come with these ports as they're old tech
If you email emerald they might be able to reccomend you a suitable convertor that works faultlessly with their ECU. dont be afraid to spend 50quid ish on something GOOD. as what you really dont want is a bad quality one corrupting the map and you then being stranded i had exactly this when mapping and me and chip were stuck for ages trying to re-flash the map to get the car to run again.
Old Jul 21, 2008 | 05:44 PM
ebit's Avatar
ebit
Who?
I bought a Keyspan usb adapter than works fine with the Megasquirt ecu.
Old Jul 21, 2008 | 05:53 PM
rapidcossie's Avatar
rapidcossie
I got a USB adaptor from Maplin for my Autronic and it works spot on!
Old Jul 21, 2008 | 05:57 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I bought a cheapy USB to RS232 DB9 off Ebay for £5 delivered from kong-hong, didn't expect much of it, but it works perfectly and allows my laptop to talk to Megasquirt effortlessly
Old Jul 21, 2008 | 06:00 PM
pee vee's Avatar
pee vee
it says in the emerald manual which type of USB converter to use mate.
and actually says that most cheap high street ones will give the Exact problems you are having... emerald sell one that will work,
Old Jul 21, 2008 | 10:13 PM
rst in breaking
this is where i got mine, but it doesnt want to reconognise the ecu but do away with the converter and use me mates old skool laptops and it works fine , chips just going to stick to the old laptop whilst setting it up, uses the good old 9 pin
Old Jul 21, 2008 | 10:48 PM
richm's Avatar
richm
Usb-serial converters are very hit and miss, sometimes you get lucky sometimes not, depends on your individual application and chipset that the adaptor is based on, either individually or in combination. The ones we have found most reliable at work are based on "Prolific" usb-serial chipset, but you have no way of knowing what's inside them generally.
PCMCIA RS232 converters are much more reliable, I haven't come across a situation yet that they haven't worked.
I recently bought this one - http://cgi.ebay.co.uk/PCMCIA-To-RS23...713.m153.l1262 and using it with Emerald with no problems. I'm not particularly reccomending this one, it was one I randomly chose, but just confirming it works with our K3 emerald.
Old Jul 21, 2008 | 11:47 PM
stevieturbo's Avatar
stevieturbo
C**t
Also, dont forget to configure the virtual COM ports so you can use them. If they arent assigned to a COM port your ecu can see, it will never work.
Old Jul 21, 2008 | 11:48 PM
rst in breaking
im not the best on computers, does this mean just loading the software up for it? if so ive done this, cheers
Old Jul 22, 2008 | 05:03 PM
pee vee's Avatar
pee vee
did you work out why the TPS was out?
Old Jul 22, 2008 | 05:13 PM
stevieturbo
C**t
No...you need to go into Control Panel/System/Hardware/Device Manager
The go to the COM ports section, and you should spot your USB adaptor in there somewhere.
Go into its properties and somewhere there will be an option to assign it to certain COM ports ( COM1-whatever )
Most applications can find 1-5, so choose one of these. Hopefully there is one vacant. If you choose one that isnt vacant, it might interfere with the operation of other devices.
j.hammond1
30
Oct 31, 2021 05:28 PM
155lee
14
Aug 22, 2015 12:15 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
