MADrod, update thread, graph on page 2, gasket problem, 793bhp but still more to come
Old 16-07-2008 | 05:22 PM
  #121
Chip's Avatar
Chip
*** Sierra RS Custard ***
JB, the 793 was on race fuel, apologies for any confusion there mate.
Old 16-07-2008 | 05:23 PM
  #122
NEIL A's Avatar
NEIL A
Awsome results , just a shame about the gasket.
Would a gasket the same as me and Euan are now running be any use , its a mls with seperate fire rings, im sure it also gets fitted with some kind of bonding agent. There was pics in the post euan put up the other day.
Old 16-07-2008 | 05:27 PM
  #123
Chip's Avatar
Chip
sounds a similar thing to what I am recomending
Old 16-07-2008 | 05:30 PM
  #124
NEIL A's Avatar
NEIL A
I just had a look and the pics arent very clear but im sure euan has some others that were better if not Alan will be able to let Mark know the story with them.
Old 16-07-2008 | 05:31 PM
  #125
Chip's Avatar
Chip
Im sure Mark is aware of the options anyway mate, just didnt know till today that they would be needed.
Not a huge deal, but certainly a pain
Old 16-07-2008 | 05:46 PM
  #126
Stavros's Avatar
Stavros
DEYTUKURJERBS
Idve thought at this level, the difference in cyl pressures that 2 and 3 bar boost gives are relativley fuck all, so boost pressure itself isnt the issue in the slightest?
And yeah, Skylines rarely do big torque, they do big power and big revs, so less of an issue in that respect for them.
Just for fun I posted this on the GTR board and they are amazed one of their "little" 2.6s can be so torquey and give such a good powerband, race fuel or not I didnt actually say what engine it was
http://www.gtr.co.uk/forum/upload/10...4500-good.html
Maybe theirs would if they wasnt mostly specced so strangely most the time...
Old 16-07-2008 | 05:48 PM
  #127
cosy trav's Avatar
cosy trav
Awsome power and torque out of that engine , bet there glad the gasket went before they fitted the engine in the car .
Them gas filled ring look like a good answer to the gasket problem as they will expand to give a good seal .
Hope it gets sorted soon so we can all see the full engine output .
Will his transmission be able to cope with the serious amount of torque that its going to reach ?
Old 16-07-2008 | 05:49 PM
  #128
Chip's Avatar
Chip
Well peak cylinder pressure is effectively decided by the det point of the fuel, and the shape of the chamber and speed of the pistons etc, so you may be correct there mate, as less boost would have meant more timing, and potentially still similar pressures.
It might be that Mark has effectively done such a good job of the pistons and head etc, and choice of fuel of course, that the det point is MASSIVELY higher than we all are used to, and hence he was running loads more timing than we would think he could get away with, and hence higher cylinder pressures.
It would certainly explain the MONSTER torque!
He could potentially take 5 degrees out of the timing, lost 30bhp, and it last forever, even on gas, or it might not be that simple, sadly, its NOT an easy thing to find out!
Old 16-07-2008 | 05:51 PM
  #129
Chip's Avatar
Chip
LMAO @ that thread
Old 16-07-2008 | 05:53 PM
  #130
Staffi's Avatar
Staffi
Just off topic slightly regarding the gasket, what kind of top-speed would the saff be capable of now with the 793 power figure?? i forget what the old engine produced, probably been put on this thread somewhere and i've missed it..
Old 16-07-2008 | 05:55 PM
  #131
Porkie's Avatar
Porkie
WICKED!
I didn't realise the cylinder pressures were not much different. Sorry... I thought 3 bar was mentally more.
Guess I'll leave it to the pros
Old 16-07-2008 | 05:56 PM
  #132
Chip's Avatar
Chip
Rod ran 206 with no more power than that IIRC
Most his old engine ever saw was probably nearer to 900 (purely an educated guess, no dyno figure to back up my "claim" im just trying to answer the question), but it never completed a run like that before it broke the block.
That figure without nitrous is probably good for best part of 210 Id imagine just cause of the shape of the curve (ie massive everywhere!) its area under the curve used (used being the top third of it in this instance) that matters more than the peak figure
Old 16-07-2008 | 05:57 PM
  #133
Chip's Avatar
Chip
Originally Posted by Porkie
WICKED!
Because you run less timing, the cylinder pressure stays the same, but lasts for more degrees of crank rotation.
Its perfectly possible that at even 1.5 bar of boost, in this engine and on this fuel, that it would have done the gasket.
On pump fuel, it would almost certainly NEVER have done that to the gasket, so that 726 they saw probably would have done 10,000 miles, even at 2.7 bar of boost or whatever it was, or even if it peak at 3 bar for that matter.
Old 16-07-2008 | 06:08 PM
  #135
Chip's Avatar
Chip
Originally Posted by Matt J
this may sound thick but why was the gasket not an issue on the old 900 engine?
Because it saw less cylinder pressure for a bigger % of the cycle to make the power.
If this new engine (as it was intended too) had held the pressure it was doing on the dyno but for the sort of number of degrees of crank rotation the engine saw last time, it probably would have made 1100-1200 BHP
800bhp or 900bhp isnt the issue, its the cylinder pressures used to get to it.
On nitrous you can get away with lower pressures for longer time periods
Old 16-07-2008 | 06:12 PM
  #136
Rhys's Avatar
Rhys
Gutted news on the gasket! But some VERY impressive figures being shown. Keep us updated on the news wether it is the gasket or something else. Hopping its not going to be anything to serious.
Monstrous engine.
Old 16-07-2008 | 06:26 PM
  #137
Turbosystems's Avatar
Turbosystems
Super Moderator
@that thread when you going to tell them it is a ford, how long you going to string them along
Old 16-07-2008 | 06:32 PM
  #138
Chip's Avatar
Chip
Its got 450lbft at 8000rpm and someone is saying its dropped too much, but reality is person saying so and posting his graph only has 400lbft at 7500rpm on his graph, lol
Its just that rods make such MONSTER torque in the midrange it makes it look like its tailing off.
Mind you if they knew the midrange spike it was running (2.7 bar) they might understand why, lol
Old 16-07-2008 | 06:33 PM
  #139
rs-tuner's Avatar
rs-tuner
that will be an animal to drive looking at that graph.
Old 16-07-2008 | 06:34 PM
  #140
bud-weis's Avatar
bud-weis
Football Cwazy
How certain are they that it's the gasket that is the problem, and not the bolts they are using??
just wondering if the head has lifted slightly before the failure?
Old 16-07-2008 | 06:36 PM
  #141
Chip's Avatar
Chip
They are certain the gasket has failed, im sure they cannot be certain of why just yet, and TBH even when its apart, you dont know if the head lifted, or at least didnt pull down as hard, briefly as the failure happened
  #142
Stavros's Avatar
Stavros
DEYTUKURJERBS
No they wouldnt as they think anything lower than 8.6:1 comp is the root of all evil and cant seem to run more than 1.5bar on pump fuel, so 2.7bar on pump gas would be like speaking some strange alien language to them
I nearly replied to that guy to explain how poo his powerband is, your average Cossie engine with his power has a better powerband, but couldnt be arsed.
Old 16-07-2008 | 06:38 PM
  #143
Chip's Avatar
Chip
Your cover has been blown now anyway
Old 16-07-2008 | 06:40 PM
  #144
Turbosystems
Super Moderator
his power graph was on a hub dyno to fair to him but he still had a very narrow power band
if you tell them it was 2.7 bar they will probably assume that is absolute
Old 16-07-2008 | 06:42 PM
  #145
Chip's Avatar
Chip
  #146
Turbosystems
Super Moderator
thanks adam what a spoil sport would have been seriously funny ruined now
Old 16-07-2008 | 06:43 PM
  #147
JAP CRAP's Avatar
JAP CRAP
Yeah he's chatting some good shit that guy.
also look how much torque its making and even earlier on compared to that skyline graph which I would assume is on a much smaller turbo package due to making way less power/torque!
The spread of torque on Rods engine is mad.
Old 16-07-2008 | 06:51 PM
  #148
rapidcossie's Avatar
rapidcossie
I run one of the cometic phuzion gaskets and it seems like a good set up.
Obviously way off the pressure Rod's engine is putting thru it tho.
the seperate rings can be seen in this pic.
Old 16-07-2008 | 06:52 PM
  #149
Chip's Avatar
Chip
Good choice for an off the shelf job IMHO Euan.
AVA specced you to have that I take it?
Old 16-07-2008 | 06:54 PM
  #150
leecavturbo's Avatar
leecavturbo
what gasket arrangement has norris used to build his 4 1000bhp+ engines?
Old 16-07-2008 | 06:55 PM
  #151
leecavturbo
never heard of these till just , love the idea tho
Old 16-07-2008 | 07:45 PM
  #152
Chip's Avatar
Chip
Very cool idea IMHO, and not mega money either.
Old 16-07-2008 | 07:49 PM
  #153
rapidcossie
Yeah Alan suggested we go to these for the high powered engines.
Mine, Neil's and cossie916(sorry forgot your name) have all got them.
Old 16-07-2008 | 07:51 PM
  #154
PF Dave's Avatar
PF Dave
You should've heard it Chip! The sound of it coming on boost hard over about 500rpm was quite something!
Poor Norri's dyno...
Gutted for Rod.
Old 16-07-2008 | 07:53 PM
  #155
Chip's Avatar
Chip
Gutted for Rod.
I was gutted I couldnt make it today, had stuff to do in the office sadly so couldnt get away
Old 16-07-2008 | 07:55 PM
  #156
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Just got home.
A big shame to an exciting day. Engine was just going to be recored at 6k on race gas. I saw 790 something bhp uncorrected just before the gasklet let go. Is a brute of an engine and the way it produces the power. You can all see for yourself the lb/ft at 4k and then the lb/ft at 4.5k
The noise of it spooling up and hititng full boost is just incredible
Gasket let go at circa 3 bar boost. Blew the water feed pipe off the dyno. Feel sorry for Rod and Mark. Maybe a more manyl headgasket is needed. The 120 ron race fuel and ignition making such huge cylinder pressures are to blame
Great day out though
  #157
Munch's Avatar
Munch
Mr. Sparkle!
Dam that GTR thread could of been fun
Old 16-07-2008 | 07:57 PM
  #158
Stavros's Avatar
Stavros
DEYTUKURJERBS
So it got 790bhp (uncorrected) at 6k before the gasket had enough?
Old 16-07-2008 | 07:58 PM
  #159
Miller 3's Avatar
Miller 3
Fantastic results guys' Im sure it wont be long before its back together again
Old 16-07-2008 | 07:59 PM
  #160
Chip's Avatar
Chip
Rod said he saw 675lbt just as it went, so cant have been much over 6000rpm if it was making "only" 790odd, so that sounds right stav.
you done the maths for even if it just held onto 600lbft at 8000rpm? !!!
Quick Reply: MADrod, update thread, graph on page 2, gasket problem, 793bhp but still more to come
