Scart cables over 1.5m. Is it bad? (Now.... hanging a plasma topic.)
Ive noticed most places selling decent quality interconnects dont sell over 1.5m,presumably due to signal degredation. We are uying a new Plasma for front roo and the route through the wall is being plastered on Thursday so i need to allocate the cables ASAP. HDMI 1.3b and The Lan ad power cables are sorted, but... Scart seems to be more of an issue.
Question, when locating your plasma on the wall, how have you conncted your sky+ boxes?
just finding my feet
ive built in a panel on the bottom side of the fireplace with , its a little like a plug socket type arrangement or a extention to whats on the back of the tv..... though i aint labeled mine so it was intersting discovering what went where
not sure about scarts though cause i used dvi, 3 hdmi and audio inputs but scart is there should i find a way to test
Not speaking from experience of using one, but you can get long run Scarts Nicole..
http://www.clearly-av.co.uk/listings...rt-Cables.html
http://www.tvcables.co.uk/cgi-bin/tv...ead-lindy.html
Maplin.co.uk , Richer Sounds etc. also do them.
you can run them I'm sure mine is around that length although I probably woudn't buy cheap.
My plan is to get a amplifier with HDMI outputs so that I can plug all my equipment into that and then just have one hdmi cable going to the plasma.
Also could you not get some tubing that you can put into the wall which you run the cables through, that way if you need to replace or upgrade a cable all you need to do is pull the new one through with string.
cant speake for sky,but i had to use 2m hdmi cables to conect my Virgin to the plasma,i had a rainwater down pipe built into the wall to take the cables,i stuck with Virgin as i didnt have to re route the phone socket.
As for long scarts,cant see you loseing much quality over a 1.5m one tbh
Thanks guys, will look into it further and click buy it now on one or two items. Plasterer is here Thursday and i clean forgot i had to do this.
Most of my setup is going to be aorund small media centre pc's, and hopefully distribute the sky using cat5 cable yet to try this trick, but it apparently works without losing any of the signal quality
EDITED to say
what equipment have you got?
are you looking to only watch that equipment through that plasma and not distribute it else where in the home?
Ordering the new Vierra 46" Plasma. Will be cabled into the gigabit network allready existing in that room for the PS3. Other than that, ive not looked at any othe options.
very nice, have you got or do you want a surround sound system as that is really the back bone of my system
also you are limited by the connections of the sky box (presume the reason for your installation is to hide all wiring), the tv has hdmi, vga, scart and component at the rear. but the sky box only supports scart and component.
If you didn't want to get an amp just yet I would suggest running both scart and component cables, that way you could pick the one that offers the best quality connection from your sky box, unless you have time to test it all before its all built in, if you will not have access to the wires in the future its probably worth chucking in 1 or 2 hdmi cables for piece of mind
This is my current setup with what I will do once I have found a suitable amp.
media centre optical out into amp, hdmi out has to go the tv at the mo as the amp doesn't support hdmi - but will be hdmi to amp
sky +, optical out to amp, s-video to amp
then s-video to plasma - with new amp will be hdmi
WII just straight plugged into tv, will be looking at getting it through the new amp
From the sky box I will be looking at distributing the signal to each room with a tv, all pc's networked and most probably a nas box for file storage and sharing
Thanks for teh advice. I plan to run:
2x Scart 1.3a cables.
1x scart cable
1x Cat 6 lan cable
1x power cable.
That will give me access to all the most likely used TV rear sockets, however, if you recomend component as a good set too, then i will grab a good set of those from ebay today and run those too.
1x scart cable
1x Cat 6 lan cable
1x power cable.
0-60 in 17 seconds (eek)
Stu, no problems with long scart, get a reasonably priced quality one and you won't have any problems, I've used 5m scarts many times.
I'd run as many cables as the plasma will take and then some...
You haven't mentionned any aerial cables, or satellite cables. Many tvs in the future may run internal satellite decoders for things like freesat.
An aerial cable will allow you to watch a freeview channel while sky is recording two
Component is probably not necessary since you've got HDMI, but you only get to do this once, so again, I'd run a set just in case.
No Sky+ box has HDMI, you need sky hd for this. You should be able to get a HD box and not pay the Ł10 for the HD channels, so you have HDMI, but no HD
Finally, if you are planning (or already have) an AV amplifier, most come with switching such that any input (component, s-video, composite, etc...) is converted to HDMI so you theoretically only need run one cable from amp to tv.
Finally (take 2). Run some plastic pipe in the wall along with the cables so that you can draw some other unknown yet kind of cable. Much better than burying them in plaster - see below.
as frog said best to run more than you actually need to start with, but also do the tubing in the wall so you can upgrade change cables in the future as that will save you a headache.
I know it seems overkill but you will be grateful you did it in the long run
Thanks Fellas, this TV has freesat built in and will decode Free HD too, so your right, i am running a Coax cable with it too, but forgot to list it. I will also need to run some form of sat cable as well, which i am on with sourcing now.
Sadly, this isnt a stud wall but a brick one, so running tubes isnt going to be easy. In fact, i havent decided what the hell im going to do with it yet! But i need to do it between now and tomorrow night, which technically, means tonight.
Thanks for teh advice fella,s i really appreciate your time.
They now have a HD projector and prehistoric cabling which can't be changed unless the expensive bepoke wall paper is torn off the wall
Stuck with crap picture quality for the sake of some good design.
If the wall is brick wall, you may be able to create some form of trunking or channel on the wall (thinking shallow wooden box or something), rather than in the wall. It would be on show obviously, but, would be future proof.
why not raise the wall a little bit stu and have the screen flush with the wall ( which is what i have done ) that way theres no gap at the back either
i used plaster board for mine though and its on the chimney so the heat escapes out there
The wall is a feature wall with 2 bay windows built into it so i cant alter its dimensions at all. The Tv may actually be ever so slightly on teh large side, but the model below looks ever so slightly on teh small side and isnt an award winner, so ive opted for the 46. As i see it, i may just have to run maybe 3 sepoerate channels and lose the wires in there forever, plastered inside some plastic trunking. Not a drama really, its high quality HDMI of teh latest spec so should be quite future proof. We have also opted to paint that wall a seperate colour as a feature wall, so not too much of a nightmare should the worst happen and we have to run a new wire. Plasterer is a drama and a mess, but at least its just a repaint for that one wall.
Will try and find a picture.
Glad to help out Stu, nice to give something back since I have learnt alot from your fantastic articles in Fast Ford.
Would be good to see a before and after pic of your installation as I'm still looking for ideas on how to mount the plasma and equipment
Here we go:
That is the Panasonic Vierra 37" Plasma, and as you can see, its an ok size for a room of those dimensions. The 46 is going to fill that bay leaving 5" clearance either side towards the windows, so should fill it nicely.
"If" i ever get it on teh wall, as it sounds as though its been boarded, so, what lies behind? Bloody brick i prey, as these TV's are heavy.
Live long and prosper!!
Now all you need to do it sort out how to hide those cablesshame it was'nt a chimney breast you could baten out by an inch and where your bracket will fit(if your havin one) plaster board skim job done
BUT U CAN'T
So how about having a Piller upto the TV 18" wide 2" deep and cut the skerting to around at the bottom??
Just an idea which won't take long
Paul
BUT U CAN'T
Paul
even football/tennis wasnt all that either though wildlife programs was the nuts ( under the sea stuff ) shame i dont watch that sort of stuff apart from to see how good HD is
how many channels is sky HD
On the other side there still aren't very many HD channels on sky, so is it really worth the extra Ł10 a month, but then like someone else posted above get the box but don't subscribe to them until you get value for money, at least then you are taking advantage of the connection on the sky box.
Resident Wrestling Legend
point the first:
each box is mathed to the card, so you need to phone sky and tell them to match the card you have to the box you have
this will mean you will have to tell them what box you have
this means they will find out you have a hd box
this means they will charge you for teh hd service
the hd box has th channels unlocked already so you can watch them with any card you have in the box regardless of it it's been matched or not, but without a matched box you only get about 20 channels
point the second:
get one if these and you can run 4 hdmi cables to the back and then one to the telly, and the fact that it's fully 1080p ready and able means that the length of cable won't make that much of a difference
point the second:
Starting to err on the side of the 42" now. Measuring up accurately, the 46" is slightly too big and i absolutely hate rooms with TV's in that are too big. But i feel the 42" may be too small as its only 5" bigger than the one i have. (Only?)
Fooking aggro. Need to buy it on the way home from work too.
To big and potential spoil the room? or too small and be disspointed?
And how much is a SkyHD box nowadays?
These guys do big long scart cables and boosters, wall sockets.. the lot hth
http://www.nexxia.co.uk/
the HD is 10quid a month.
thats a big put off. you pay 10quid to get exacly the same channels but a FEW programs will be broadcast in HD. thats not much for your money, you could get all the movie channels for the same price.
once the price comes down or they add more content then i think it'll be worth it
Ł150 from sky iirc, maybe slightly cheaper on eBay but not by much.
Dojj, not sure that sky would force you to pay for the HD programmes, it's an extra you can take off, just like movie channels. It's not because you call them that they turn everything on (although they will try )
SKY HD mix is additional to subscription, so it's optional, regardless of the box you have.
Freesat HD only (for now) has two HD channels BBC and ITV (ITV isn't on sky).
Sky HD has: FX HD, Rush HD, Sky Movies Premiere HD, Sky Moves Screen 1 HD, Sky Movies Screen 2 HD, Box Office HD, Sky sports 1,2 and 3 HD, Sky one HD, Sky arts HD, Channel 4 HD, BBC HD, Discovery HD, National Geographic HD, History Channel HD.
That's a fair few HD channels tbh, many more than when it first started
Mine's fitted onto 2" studs that are attached to a breeze block wall and hasn't shown any signs of movement yet. I also have 12mm MDF boards to give the whole thing more strength though. (Build pics here http://slideshows.scullard.com/plasma/)
Benefit though would be that running cables is a doddle in a stud wall compared to bricks
Old CRTs weren't hung on the wall, and that's not just because they were bulky, it made sense for them to be at eye level.
So, if you're planning on putting your plasma on the wall, think about where you're sitting in relation to it, and you'll probably find it needs to sit lower than you think
Did you find out what was behind ? Decent joists in a stud wall should be well up to the job, maybe requiring a little strengthening. Unless you use very good fixings in the brick wall, I'd sooner have 2" screws in wood than a dodgy wall plug in a brick that's not completely filled with concrete
All in all, it looks like if we hammer at it much more we are going to have to remove and re-plaster that wall completely, as opposed to teh simple room re-skim we have booked for tomorrow. Tiem beat me, but i will revisit the plan when we re-decoate next year.
Yes, a poorly bricked and cemented up chimney that started to crumble the more we hit it with a chisel. Then we got to the concrete vent bricks, followed by the old lime plaster wasnt boned to the brick anymore.
On a positive note, despite the amount of work required, sounds like there's plenty of space back there to run some cables though
Maybe even the possibility of small AV shelves or built-in centre spearker in the wall where the chimney was (if I understood correctly).
