Golf Mk4 De-cat
Needs Beer Tokens.....
Golf Mk4 De-cat
Had powerflow make me a pipe up to replace the cat, mot is tomorrow so putting the cat back on, will i set any engine management lights off or can i put it back on and hay presto?
Do you know what engine code you have??
The early golfs have 1 sensor.
The later one have 2 sensors.
If it's a later one with 2 sensors it is the Second lambda sensor that will cause the engine management light to come on. You can put a spacer on the lambda but it's not a definative fix and it's seems that it works for some and not for others
chris m1
07-09-2015 08:02 PM
