indicator and starting problem capri
Old Jul 3, 2008 | 09:31 AM
b_kennedy's Avatar
b_kennedy
Default indicator and starting problem capri
Anyone know what colour it is and what number pins.
Its for a capri if that makes a difference. Thanks
Old Jul 3, 2008 | 11:02 AM
dojj's Avatar
dojj
Resident Wrestling Legend
got one at home, for the sierra if that makes any difference?
although you may be barking up the wrong tree as there's another one for the hazards that sometiems goes tits up and makes nothing work
Old Jul 3, 2008 | 11:08 AM
b_kennedy's Avatar
b_kennedy
well i just got a new one and makes no difference. The problem is..............
I had to changed the dash clocks yesterday so i did. As i was connecting it back up the connector slipped out my hand and sparked in the metal part of dash. Since this when you indicate left everything is fine. When you indicate right is flashes really fast like a blown bulb. The front one works but the back one doesn't. Obviously I changed the rear bulb but it still does not work.
Also since this I havent been able to start the car so obviously something else has blown. I have checked the 7 /8 fuses in engine bay and all are fine.
Are there any other fuses or things i can check. Thanks
Old Jul 3, 2008 | 11:32 AM
Paulo P's Avatar
Paulo P
Not good I can't offer any advice at the moment but my capri is sat in my garage if you need parts to swap over to test. Mine is a 3.0s so quite a bit will be the same.
Old Jul 3, 2008 | 11:36 AM
b_kennedy's Avatar
b_kennedy
ok thanks mate. Much appreciated! you changed your name lol
trying to get hold of some diagrams so i can trace it back hopefully but no luck yet. Cant actualy find a haynes manual anywhere either. right bitch!!
Old Jul 3, 2008 | 11:47 AM
Paulo P's Avatar
Paulo P
I can't remember if I have a workshop manual for a capri or not If I find one I'll let you know.
Yeah changed the username, I was bored of that one
Paul
Old Jul 3, 2008 | 11:49 AM
b_kennedy's Avatar
b_kennedy
thanks fella. I managed to find this. Looks about right. Gonna start studying it now and hopefully done. I been working flat out to get this done and all i had to do was change clocks. Now i back to square one for a stupid accident. I'm gutted. Just wanna get happy capri'ing
http://www.capripower.co.uk/board/in...showtopic=5042
Old Jul 3, 2008 | 11:51 AM
Paulo P's Avatar
Paulo P
The electrics on capris are quite simple compared to most cars. There isn't much that can go wrong. It's a shame that diagram doesn't tell you the location of the relay for the flashers.
Old Jul 3, 2008 | 11:55 AM
b_kennedy's Avatar
b_kennedy
I found the relay so that not a problem. It said blinkgleben or something so i assumed it was flasher and was right Im good at german LOL
The lack of wiring is actuall worrying me cos there less that is fused. Hoping i dont have to re-wire loom. I hate that so much!!
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
RIB1122
Aug 12, 2015 08:51 PM
dlwarrior
Aug 5, 2015 10:19 AM
