044 pumps quick question
Old Jun 29, 2008 | 02:35 PM
escossie560's Avatar
escossie560
Default 044 pumps quick question
Whats the current draw of an 044 pump? cheers andy
Old Jun 29, 2008 | 03:06 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
12-15amps, depends on the load.
Old Jun 29, 2008 | 03:16 PM
escossie560
Thought it was some where in that area ,just bought a new summer toy and was giving it a good check over and found the fuel pump relay to be very hot ,it has had a twin pump set up and was running both pump via a 15 amp relay with a 20 amp fuse ,i have already rewired this though a 40 amp relay. Cant believe the guy i bought it off paid a well known tunner to carry out this crap . Better keep looking for other noughty bits
Old Jun 29, 2008 | 03:18 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If you're running two pumps in parallel it doesn't hurt to run two seperate relays to eliminate a SPF (single point of failure)
Old Jun 29, 2008 | 04:34 PM
JamesH's Avatar
JamesH
Mines on a 30A relay and a 20A fuse, never blown so obviously never had the current above 20A.
I do seem to remember IMA saying around 11-12A, may be wrong though
Old Jun 29, 2008 | 05:07 PM
Bosch told myself 9 amp at max load.
Old Jun 29, 2008 | 05:22 PM
RickyLee53's Avatar
RickyLee53
I take the opposite view. If 1 fails your car will still run, but it could run lean.
Old Jun 29, 2008 | 05:42 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yeah, if you've got 600bhp.
Old Jun 29, 2008 | 06:06 PM
escossie560
either way should never be off 1, 15amp relay was getting very toasty !
thanks for your replys
Old Jul 1, 2008 | 12:15 AM
stevieturbo's Avatar
stevieturbo
C**t
Ive been running 2 off a single relay for almost 2 years. Never a single problem. 30A fuse.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
155lee
Oct 27, 2015 04:55 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Bransby
Sep 11, 2015 01:09 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
