mahle forged pistons..
![Cool](https://passionford.com/forum/images/icons/icon6.gif)
just wondering if theres low comp or normal comp pistons, or are they all the same?
or does the headgasket lower the compression?
also how much would a good condition set of these pistons set you back (with conrods) 2nd hand?
cheers
cheers
you serious?
there was some on ebay stated rs turbo fiesta/escort mahle pistons...
was outbid but he said i could have 2nd chance to buy them as the winner has not contacted him
Black Country RSOC
Modified lower compression pistons are available for the CVH turbo such as 7.5 :1.
So yes, i was being serious.
i havnt got a block yet, i was going to buy them as i had plans to build a low comp bottom end, but just want to find out more info and see if there low comp pistons first as he isnt sure, just knows they are 8:3:1 comp
lofty i thought you ment there not for a cvh turbo anyway, thats why i said are you serious... lol..
so there standard comp pistons for a cvh turbo? and not the low comp ones im after...
im pretty sure there 0.5mm overside pistsons, so if i just buy a standard cvh turbo block i can just get it borded out..
Colossal Pervert
I'd be very surprised if Mahle make a 'low comp' piston for an RS turbo... They're an OE piston supplier, not some boy racer aftermarket. You can machine down the standard pistons to get a good compression ratio with no reliability problems.
Black Country RSOC
Hang on.
Do you know what spec of engine your gonna be building? Ie Capacity, power figure aiming for, turbo used, management etc etc.
Only then can people advise you what compression pistons to get, although in all honesty, unless your going for massive power, the "STANDARD" rs Turbo Mahle 8.5:1 compression pistons are more than suitable.
if you want even lower compression pistons, Accralite or someone similar are gonna be the way forward.
But you need fixed in your own mind what you wanna achieve first, BEFORE you start buying used bits and mixing and matching them.
Bodybuilding
Location: Cannot be identified by the information given.
mahle did not make any forged pistons or low comp pistons for the cvh turbo
all they can be is the standard mahles 8:3.1 cr
hard work isnt it lol
mahle do do std ow comp pistons, but they are just standard pistons with 20tho taken off as i had some years ago
but, buy the block first then the pistons,
but as said, work out how much power you want etc
as a std bottom end would be good for 200bhp all day long
Bodybuilding
yes that's exactly what the so called mahle low comp pistons are standard skimmed squeezed cast
Bodybuilding
it would be cheaper to buy a zetec 2.0 block and use some mahle vauxhall LET pistons which are forged for about Ł100 and give 7:5.1 cr
the only reason im asking about he mahle pistons as some came up cheap (2nd hand but in vgc) but as there not low comp (which i wanted) then il just leave them...
Black Country RSOC
Bonus Boy - If your looking at building a 270bhp CVH turbo, the last thing you wanna be doing is buying used pistons of fleabay!
Your gonna need deep pockets as well.
Bodybuilding
they are both 86mm so you just bore the block to 2.1
ian howell said there good for upto 400 bhp same strength has the standard cossie pistons
Colossal Pervert
Lots of thinking and thoughts going on around here.
The difference between the XE and LET pistons is if you're building a ZVH or full Zetec turbo engine. XE is more suited to ZVH's, LET's more suited to Zetecs. You can however use either for either conversion, but they'd not be ideal.
None* of these engines are 2.1 litres. 86mm bore with 88mm stroke gives you 2045cc, which is 2.0 (well, it was when I was taught mathematics).
* most
* most
Bodybuilding
* most![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
* most
yes true its only 2045cc but it would sound strange calling it that
i dont really know why they call it a 2.1L probably just to make it sound better
if thats the sort of power you want, i do hope you realise how expensive its going to be to get them figures
rods,pistons,headwork,cams,turbo,intercooler,manag ement,mapping,injectors
then you will have suspension,gearbx,brakes,bushes on top of that to hanlde the power
but as said, zetec is the way to go for that power
don't bother, buy a car thats fast in the first place and won't fall apart. Will cost you less money, and you will have a much nicer reliable car. For the money you will spend on that you could pick up a very clean saff cossie or even bottom end Escort cossie, or any other good std fast car such as an EVO etc.
