General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i know there slightly different can you adapt them to fit?
Yes, they bolt straight in but you will need a spacer between the diff casing and beam on one of the top fixings. It's about 13mm wide. You will also need to fit 4x4 shafts and outer flanges.
as said,but just change the diff flanges to 2wd ones.easy to do.just remove the back cover,remove the c clips,and out comes the flange.
