st170 brakes
does anyone know what brackets are needed to fit st170 brakes to a frst
and also where can you get them from?
cheers
steve
cheers
steve
Spanner monkey
no brackets needed mate, direct fit, all you need to do is drill out the existing bolt holes in the hub from 10mm to 12mm as these calipers have m12 bolts!
you need m12 x 30mm bolts, the exact same ones as the focus uses!
