Another Escort with 8.5"/ 10" wheels
Old 11-06-2008, 09:53 AM
  #41
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Don't like the 10" rears, as on any car other than Martin's the rear tyres look too bulbous. Must be to do with how Martin has pulled his arches?
Stick some pictures of yours up Marty for comparison .
Ztee's with 9" rears looks fantastic though - just right . However, that is obviously due to being able to run different rolling radius tyres. You have to have 265/35 x 18 and 235/40 x 18 on the 10" / 8˝"s to keep the rolling radius the same on a 4x4, as 245/35 is the biggest you can get away with on the front, but they are the wrong radius for the 265/35 rears.
Old 11-06-2008, 09:57 AM
  #42
screemin
screemin's Avatar
Originally Posted by Dan
What turbo/power? Looks lovely and clean mate!
Cheers Dan.
Turbo is just the standard T3 and at a guess power is 350-385bhp.
Gotta wait for Martin H to get off his arse and get his new spangly rolling road fitted before i get a better idea tho !
Just a couple of little surface bubbles to get sorted on it, then i might think about washing it more than once a year.
Gaz
Old 11-06-2008, 10:28 AM
  #43
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
Originally Posted by american
I thought your rears were 9", having said that it's been a while since you bought them and I can't remember for sure!
Old 11-06-2008, 10:30 AM
  #44
Edmund
Edmund's Avatar
Originally Posted by martin-reyland
Have you checked if one wheel sits in further with the Rondells fitted?
Here's a shot looking down from above...
Has that tyre been touched by the arch,you can see a line what looks like an indentation from the arch.IMO they look too big as said above the tyres look bulbous,can we see pictures of this car that they do look right on?
Old 13-06-2008, 06:46 AM
  #45
Twellsie
Twellsie's Avatar
having seen Garys in the flesh, it looks awesome
Old 13-06-2008, 06:52 AM
  #46
R5FORD
R5FORD's Avatar
still waiting to know if they fit straight on or need mods.
Old 13-06-2008, 06:55 AM
  #47
Martin-Hadland
It all depends on what shocks are fitted. Koni's will need the spring cup modifying, coil overs will clear. You may need to grind a small amount off the rear trailing arms too.. Nothing too difficult but it all takes time.
Old 13-06-2008, 07:21 AM
  #48
R5FORD
R5FORD's Avatar
so whats the biggest i can get on all around without modifying anything?? with koni shocks.
Old 13-06-2008, 09:44 AM
  #49
Mike Rainbird
Caraholic
9" with 245/35s all round . I personally prefer the 8˝s (with the same tyres, which clear my brakes no problem), hence why I have them on my car .
Old 13-06-2008, 09:47 AM
  #50
R5FORD
R5FORD's Avatar
well there more cosmetic than anything
mike post some pics of yours for comparison
Old 13-06-2008, 09:48 AM
  #51
costina
Live long and prosper!!
costina's Avatar
Now they would look the nuts on my Tina with polished rims
Off to get a lucky dip for tonite
Paul
Old 13-06-2008, 10:15 AM
  #52
Mike Rainbird
Caraholic
Look hard enough for you? (Obviously it wouldn't work on a Auralis car, as the only way to make that look hard would be a colour change :
Old 13-06-2008, 10:16 AM
  #53
JamesH
JamesH's Avatar
Mike, if the rears stuck out a TAD more they'd be spot on I think!!
Did you keep the old set for spares/track tyres or whatever?
Old 13-06-2008, 10:19 AM
  #54
R5FORD
R5FORD's Avatar
love it mike and i think anthracite would look spot on with auralis or maybe white.
hmm 8 1/2 or 9'' ..
Old 13-06-2008, 10:20 AM
  #55
Ryan
Ryan's Avatar
as mike has proven on the track you dont need any wider tyres, its all to do with suspension and geometry setup.
i think the offset and size of mike wheels are perfect for an escort, cant stand the bulbous look
Old 13-06-2008, 10:26 AM
  #56
NEIL A
NEIL A's Avatar
I run 9's and think they fill the arches perfectly had to trim the rear bumper slightly but think that may be more to do with my tires, but do think 10's on the rear would look .
Old 13-06-2008, 10:29 AM
  #57
Mike Rainbird
Caraholic
If the rears stuck out any further, I would have arch clearance problems on the big compressions at the Ring .
Yes, the old ones have my Toyos on for dry track use .
Thanks sexy
Old 13-06-2008, 10:32 AM
  #58
JamesH
JamesH's Avatar
They look much better than the 10" rears anyway Mike
Do you have a side on shot?
  #59
Martin-Hadland
Mike doesn't have 700hp and variable torque split!!
Old 13-06-2008, 10:44 AM
  #60
Ryan
Ryan's Avatar
do you struggle with traction though?
im very suprised you do on a 4x4 system, i can understand 1nd and 2nd maybe, but 3rd upwards on proper tyres and your struggling for grip?
Old 13-06-2008, 10:48 AM
  #61
NEIL A
NEIL A's Avatar
As Martin says he isnt always 4wd so he will need wider rears for when he is in rwd setting, also for 1/4 and track 1st,2nd 3rd is where you loose alot of the time.
Old 13-06-2008, 10:50 AM
  #62
Mike Rainbird
Caraholic
There are some in the Ring thread taken by Maria from her camera phone, other than that, no .
Old 13-06-2008, 11:01 AM
  #63
Ryan
Ryan's Avatar
i got this one mike
only side shot i have of yours
Old 13-06-2008, 11:08 AM
  #64
Martin-Hadland
Ryan.... Are you in an argumentative mood or something? I run about 70/30 torque split on track and with slicks fitted it still wants to go sideways when exiting a corner...
So you reckon that Mike would not be quicker on slicks?
Old 13-06-2008, 11:11 AM
  #65
JonnyBravo
JonnyBravo's Avatar
i got this one mike
Old 13-06-2008, 11:14 AM
  #66
JamesH
JamesH's Avatar
Looks good like that mike
Old 13-06-2008, 11:15 AM
  #67
Mike Rainbird
Caraholic
Try running 60/40 then .
Old 13-06-2008, 11:16 AM
  #68
Porkie
Porkie's Avatar
Marty???? did you really just type that!!!
Thats gay even for YOU!
cnut!
  #69
Ryan
Ryan's Avatar
martin completely the opposite, just trying to understand as i've never seen the car at its full potential in person other than whats been posted on here.
off course mike would be quicker on slicks there's no doubt about that, but does he need 10" wheels to run slicks? no.
Old 13-06-2008, 11:31 AM
  #70
R5FORD
R5FORD's Avatar
i may just stick woth 9''
or go 8 1/2 with nice 372mm brakes
Old 13-06-2008, 11:32 AM
  #71
Staffi
Staffi's Avatar
First time i've seen these Comps, look fantastic imo..
Old 13-06-2008, 11:39 AM
  #72
JamesH
JamesH's Avatar
Don't get any ideas to ruin the Saff
Old 13-06-2008, 11:45 AM
  #73
Spiky
Spiky's Avatar
i've been around combe with martin, and if he planted it out of the corners it didnt always want to go straight, and that wasn't at full chat
and with cold tyres, it was sideways a bit more
Old 13-06-2008, 04:09 PM
  #74
xr4x4rs
xr4x4rs's Avatar
i seen the escort yesterday, and id say if i had a escort cossie id have those size wheels as they look spot on
pics look good but until you actually see it
Old 13-06-2008, 04:18 PM
  #75
Dunccoss
Dunccoss's Avatar
some better pics of the 8.5 rims and 245/35/18 tyres
Old 13-06-2008, 05:45 PM
  #76
RS500
RS500's Avatar
I have poster of that car above my bed
Old 13-06-2008, 08:21 PM
  #77
marco polo
marco polo's Avatar
you missed out my escort has them aswell
Old 13-06-2008, 08:31 PM
  #78
Martin-Hadland
Get it on the road and I will add you Let me borrow that box for 10 mins please.
Old 13-06-2008, 09:14 PM
  #79
marco polo
marco polo's Avatar
yo mart
yep no probs , ill drop a gearbox down tomorrow you was to ring me back to let me know , i would have come down tonight no worrys tho see you tomorrow
marco
Old 14-06-2008, 03:38 AM
  #80
Fastmaul
K155MYRS
Fastmaul's Avatar
OI! Who posted my pics of ZTEE24!! LOL. I was planning on posting the pics then to my surprise they're on here.
Here's the spec's of her car's wheels.
Front 18x8 ET35 225-35-18
Rear 18x9 ET25 265 -35-18
Coilovers all around and the rear 1/4 had to be cut and pulled for the wheel to fit properly. It does rub on hard dips but other than that it's fine.
Porkie, glad you like the pic I took that about 2 weeks ago That's our new house and garage
RS500, you have the poster over your bed, I have the owner in mine
haha.
BTW, who is "American" ?
Quick Reply: Another Escort with 8.5"/ 10" wheels
