kitchen sink help
need a kitchen sink
at least 500mm x 1000mm
with a larger sink basin and drain board
NOT one of them double sink things
non reversable
with the drain on the left and the basin on the right
the problem is, no fooker does one that size and then spec
non reversable
14000+ post superhero
doesnt sound an unusual request,standard sized stuff. where have you looked? B+Q warehouses actually do quite a large selection with large displays of many different styles.
http://www.magnettrade.co.uk/pdf/sinksandtaps.pdf
Top left of page,
Is it going to be a "not paying that much for one " thing?
or;http://www.yor-appliances.co.uk/shop...roducts_id=218
http://www.yor-appliances.co.uk/shop...roducts_id=841
Top left of page,
it's got to be top mounted over the existing hole in the work top, and seeing as the one thats in there is that size i can't go smaller without having to change the worktop
which involves a lot more work than just the sink
but i want a decent one so that when the tap goes in it won't flex like the cheapy ones do
Top left of page,
Top left of page,
the other 2 listed are to small for the hole currently in the worktop
thats a standard size for a 1000 base unit so you should have no trouble finding what you want ranging from under a hundred quid stainless steel upto several hundred quid for composite.
