Bodyshop people.......
#43
Check out my resto thread if you are remotely interested LOL.
#47
My new roof should be on for National day - took about a year to source mine and have had to have a non sunroof in the end.
I understand what you mean about your car Christian. Several people can’t understand why my cars had good money after bad – but it’s done some big miles and deserves a bit of tlc and I love it so I don’t care
I’m going to see Bob on Sunday, as he’s painting my tailgate for croft
Will let you know what he thinks about how much it’s going to cost
#51
Repair it. Not that hard. Dentmasters way is good, then loads of waxoil where the sunroof frame meets the skin, as I think thats where it starts. As you say the surface rust is just that and not really an issue.
#52
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
PM me if it's of interest
#53
cut the roof off and replace it it aint actualy that hard and ity aint like you never worked on a car you just have to know where to take it off from and thets easy
#55
souldnt cost that much to do the roof mate ill see if i can find you a roof up here and get it sent down to you do you want it with or without sunroof hole
#58
infact, my local scrappy has had a fair few mk4 escort bonus's in for a while now, at the back on top of other cars so i doubt the roof will be touched, ill be passing tomorrow, could call in if you want and see if they are any use? I wouldn't mind taking the genny and a grinder and sticking it on a pallet if need be.
#61
my suggestion would be to take it to an old school coach builders, they could wheel up a panel to mach the contour roof to fit in the area that needs to be replace and also a doubler panel to sit underneath it, this could then br rivetted into place using solid rivets countersunk on both sides, then all you would need would be the lightest skim of filler and spraying.
#62
Maybe stick to tuning eh rick if you think dentmaster can fix iron oxide
#65
Its Broken.....
Christian, there may be a remote chance i have a non sunroof'd car coming up very soon, and the roof can come up with TT & billycabrio....... leave it with me. trouble is i will have to buy the whole car. let me know. ( its a scrapper)
#66
at 50+ quid an hour to fabricate a roof taking around 2 days with 2 guys sounds like a good cheap way!
personally i'd look for a roof you'd end up with a nice job done relitavly quick, or get it repaired and it may last a year or 2.
#69
he is on about making a new roof skin mate and it would take atleast that to make and fit a roof skin and you need atleast 2 people to use an englis wheel on a peice that size even a skin will take 2 to 3 days to fit and paint
#70
isn't it
Trying to get a big surface flat with a little DA buzzing away will leave low and high spots, but if you make an 18inch flexible 80grit block you can skim and flat the whole roof if need be. It's not that hard, but takes a long time. I'd repair the individual spots and leave them deliberately a little low. Modern body filler is amazing stuff.
rog
04-09-2015 12:10 PM
TIL13R
23
27-05-2005 10:55 PM
