Diesel Gerbox for RST?
anyone know if a mondeo 2.0TDDI Gearbox will fit my CVH engine?
Also will I need the clutch and fly wheel or can I use the CVH?
I have seen many people in the past in mags and on websites saying they have a diesel Gearbox what’s the Score?
Any info is appreciated
The MTX75, IB5, or the BC? Yes, for all. You can't use a IB5 or a MTX75 with a rear mounted starter as it will interfere with the CVH oil filter. MTX75 also needs special gearbox mountings and modded driveshafts because of the spline pattern. You also can't transferr your RST's LSD to the MTX75 box, it will go into the IB5 though. mk3/mk4 Escort diesel boxes are not any stronger than the RST BC gearbox. However, the later ~92- (?) Escort 1.8 Diesel boxes are IB5 boxes and have larger bearings on the crucial places. I'm also using a large IB5 bearing with a separate inner runner in the BC boxes I have built. Haven't broken any yet.
thanks for the great info guys
The gearbox is from a Diesel Mondeo and its the new 6 speed, not sire how simular it is to the ST170 and ST200 Gearbox im just trying to find out, will reply here when i have some more information
cheers
cheers
So it's the twin-layshaft Getrag box. Never seen one in an RST before. It propably won't go together with a CVH block and needs a Zetec bottom end for the starter(?) All the newer bosex also have a cable controlled gearchange mechanism.
07-10-2015 12:56 PM
