Please Help A Mint S1 Turbo Back On The Road
shagger
Hello all, My pal just bought a mint s1 turbo with a few little minor probs, but got them all ironed out except this weird noice from the motor .When you are revving it on the way up the revs its fine ,it is coming back down the revs it is there. Now I wasnt sure what it was ,sounded almost like a inlet manifold gasket or a sticky lifter so changed both exhaust and inlet and a set of lifters and the is still there PLEASE HELP ALL SUGGESTIONS WELCOME
shagger
allmost sounds like fuel is exploding in inlet done a compression test and it ok 1 of the spark plugs is fouled compared to the rest could this be a faulty injector or metering head please help as its the guys first fast ford
It Wasnt Me!
Take It To A Garage
the guy thats fixin the car is better then most so called garages!! so takein it to a garage is just been wide in my eyes mate!!!if you dont have any help or idea what it is why put sumthing so useless "TAKE IT TO A GARAGE"on??
thats why we put it on here so sum1 might have had this problem before being a ford form and all ment to help each other out???????????????????????????????????????
hold on, if he has no idea whats wrong with it, and i'm assuming he does not have proper diagnostic and monitoring equipment, how is he gonna fix it based on a few comments on an internet BB?
especially with a description like "it makes a funny noise"
NOBODY here can answer that question properly
You could eliminate a faulty injector by changing it it to another cylinder and see if the plug fouls up on that cylinder.
It is very difficult to say what it could be though without hearing the noise.
Shizzle My Nizzle
sounds like either a vaccum leak or fuel/electric circuit.
check pipes
check silver and black relay under drivers side dash
does it have a dump valve, these can cause a lot of probs. if yes, take it off and blank the hole, see if it cures it!
any pics matey?
check pipes
any pics matey?
RsS2daz
Alloy wheels and ICE for sale
29-08-2015 09:08 PM
