High Pressure expansion tank cap(20psi)
Hi all need a bit of help im running a spec r tank on my cosworth but it appears that the 10 psi pressure cap im running isnt sufficient to keep the water in the tank under load. So require a higher pressure one i have been told that you can get 20psi caps but was wondering where from any help or advice appreciated regards Alex.
