hyd clutch on escos
just bought a reyland hyd clutch conversion for my escos and wondered where exactly do you mount the master cylinder.
pics would also be helpful.
Cheers guys
Cheers guys
Monte Geek
I'm just about to do mine aswell, once you have done the pedal mods and I'm told you re-fit the clutch pedal box, hold the pedal at the height you want it to be (personally I will hold it the same height as the other two) then holding the rose joint on the pedal level vertically you pin point the hole with an imaginary line to the bulk head (was going to use a laser pen) You then need a 35mm Qmax cutter and cut the hole out and mount the master cylinder.. sounds like a mission
I'm just about to do mine aswell, once you have done the pedal mods and I'm told you re-fit the clutch pedal box, hold the pedal at the height you want it to be (personally I will hold it the same height as the other two) then holding the rose joint on the pedal level vertically you pin point the hole with an imaginary line to the bulk head (was going to use a laser pen) You then need a 35mm Qmax cutter and cut the hole out and mount the master cylinder.. sounds like a mission ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
my kit is second hand so didnt get anything with it.
