any 1 know!?
cannock is a race track
any 1 know!?
who does an 165mm disc and calliper upgrade kit for a mk2 fiesta xr2? tried hispec, but he want £600 for 250mm, i really want 265 or 260. seen loads of kits out there alot cheaper than £600, just not for my car. please help, any1!!!!!!!!!!!
thank you
thank you
As said MANY more choices, mostly dependant on WHAT wheels you have ?
S2 brakes will most likely fit straight on if you have the room in the wheels, these are 260 but cheap if not cossie brakes, 273mm(4wd) or 283mm(2wd).
After that 325mm FRS discs with FRS brembo four pots, still going to be cheaper.
The best bit though is you will get them THIS YEAR, unlike HI SPEC delays and promises.
I had some brake stuff don by Geoff years ago, NOT inmpressed with blasting grit being left in the calipers, and I DO mean inside where the piston and fluid are, or the brake kit his man fitted, 100 miles later 2 knackered bells due to PADS contacting the bells every time the brakes were applied, ground through the bells outer edge and onto the bolt heads!!
