lambda on managment?
Old May 21, 2008 | 08:50 PM
col cos1's Avatar
col cos1
Default lambda on managment?
i fitted a lambda in my down pipe when i changed to l8 on msd closed loop
so i had to fit a pin in the ecu loom plug to run the lambda
question is,im about to run a collins performance ecu which is enclosed in a p8 ecu casing
whats the chances of the pin mating up to the right place
Old May 21, 2008 | 08:56 PM
foreigneRS's Avatar
foreigneRS
Testing the future
quite high i would say, as it was designed to be a direct replacement. can you download a manual or wiring diagram, or get one off someone who already uses it (neil a isn't it)?
Old May 21, 2008 | 09:00 PM
col cos1's Avatar
col cos1
yeah im sure ava have neils instructions/disc,id just like to have everything done before trailering it through
Old May 21, 2008 | 09:02 PM
rapidcossie's Avatar
rapidcossie
TBH mate I wouldnt worry to much about closed loop fueling as Alans maps seem to be quite fuel eficent compared to some.
Old May 21, 2008 | 09:07 PM
col cos1's Avatar
col cos1
sounds good,its worth having it anyway i think,im sure hes had to put the wideband reader thing in its place before when it was maxing the greys
Old May 21, 2008 | 09:12 PM
rapidcossie
I think the wide band sensor is bigger than the lamda used for the closed loop fueling tho I may be wrong?
Old May 21, 2008 | 09:19 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
...........just wondering....what does ur car go like with ur cloosed loop/ lamba unplugged
Old May 22, 2008 | 06:27 AM
Widebands normally 18x1.5, though you can get smaller for either ones wide or narrow.
Audi EGT same size as well.
Old May 22, 2008 | 06:39 AM
NEIL A's Avatar
NEIL A
Im sure the pin outs for l8 and p8 are the same so the colins ecu should just be plug and play as thats what it was designed for.
Old May 22, 2008 | 05:27 PM
col cos1's Avatar
col cos1
only time it ran without the lambda pete was when first built,on greys etc with an unknown chip it was shite,wouldnt idle and over fueled etc
cheers neil ,the answer i was hoping for
mk3ste
Oct 17, 2021 10:09 AM
tankybaby66
Feb 6, 2016 02:24 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
griffo69
Oct 4, 2015 11:58 AM
deathrider666
Sep 28, 2015 06:12 PM
