focus st3 wirin help please
i would say black is ground red is ign live and yellow is live or red and yellow round the other way u need a mutli meter and just put the earth on a good earth and put the live on the red or yellow with the ign off u will get a reading if it pernment live once u done that put the ign on to number one and do the same with the live and u should get two reading as one is pern and the other is ign just turn the key of and the one that stil give u a reading is pern
the standard ST3 unit is pretty poor IMHO, the early ones don't even play MP3's
I changed mine to one of these, and it sounds miles better.
I hope your not cutting the Ford loom, can't you get an ISO lead and use that ?
You wont find a switched live on the back of the new ST3 stereo if I remember correctly it has can bus.
But there is live and earth, solid black should be your earth and green and black live - if there is orange and black and green and black then it will have both switched and perm live.
To be honest if you're attempting this without a test light or any resonable knowledge at least, you're asking for trouble with modern car wiring.
Hope this helps.
Hope this helps.
wowk
30-03-2021 07:49 PM
