Cosworth Abs Problem????
my sapphire drives fine, brakes work fine. abs light comes on on start up & goes out nearly straight away. abs light comes on though when I take it past about 130 mph ( on a track obviously)
any ideas?
was thinking that a sensor resistance may be slightly off but not enough to show up a big enough speed difference to put the light on until i get to about 130.
all sensors have been cleaned etc any other ideas appreciated
any ideas?
Mine would come on at 90 on my private test track, it was down to a damaged pickup ring on the OS CV joint. Remove the ABS sensor & using a torch you should see the toothed ring. A couple of the teeth on mine were bent over.
Replaced the joint & no problems since.
Jack and the Beanstalk
09-08-2015 07:03 PM
