Lambda wiring, Help please
Old May 15, 2008 | 10:09 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Lambda wiring, Help please
Wires on the plug are Black/White/White-Green
Wires from sensor are Black/White/Red
Question is, Do they just match up? black to black , White to White and red to Green/White?
Might be common sense, But I'm just checking
Caught the wire the other day and it ripped clean out
Thanks,
Old May 15, 2008 | 11:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
one will be ground (most likely black, but not necessarily), one will be sensor signal out ( 0 - 1 V ) and one will be a 12 V supply to the sensor to heat it. it's crucial to get them the correct way around.
using a multimeter, you can put it in resistance mode (Ω) to check on both sides of the harness which one is ground (will be 0 ohms resistance or a beep if your meter does that).
then with the meter in volts, put the black meter wire to ground somewhere, and using the red wire check the remaining 2 wires on the car side loom for 12 V with the engine running to find the heater supply
to find the sensor output, again with the black meter wire to earth, the red one should be used on the sensor to find the output.
EDIT: from http://members.pcug.org.au/~jdeakins/facts.html
With Titania plugs:
Black is Reference (Out)
Red is Reference (In) and Heater (+)
White is Heater (-)
Output is 0 to 1 volts.
but you'll need to match that up with the car side loom
Old May 15, 2008 | 12:17 PM
Charlie Chalk
Unknown.
Thanks Nick, Just looking at pictures of my car from when I've worked on it before and it seems it goes
Black - white
White - Black
Green/White - Red
Old May 15, 2008 | 04:57 PM
Black is always a signal return, but signal return is not always black, sometimes it is blue etc
ps think about it carefully
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Si B
Sep 12, 2015 06:49 AM
