does anyone know? sapp cossie piston
ZETEC TURBO
does anyone know the following of a standed 2wd sapp cossie piston
Bore size
Dish volume
Pin size
Compression height.
Bore size
Dish volume
Pin size
Compression height.
Football Cwazy
Bore Size and pin size will be in the cosworth manual, but i dont have it to hand at the mo...not sure if the other info will be readily available though.
cylinder bore size is 90.8mm...so if you know the piton to bore clearances as standard then you can work it out, i can't remember it though lol.
deathrider666
28-09-2015 06:12 PM
