Help needed fittig ap 6 pots
04-05-2008, 10:10 AM
can anyone give me some help fitting my ap 6 pot please?
just need to know where the 6 washers go please?
thanks alot
04-05-2008, 10:12 AM
are they not to space the calipers correctly?
04-05-2008, 10:14 AM
Former Sponsor
Quote:
Originally Posted by
taycoss
i hope not!!
04-05-2008, 10:35 AM
Resident Wrestling Legend
i fitted mine yesterday
the only plae i needed to put washers was on the nuts/bolts that held the actual caliper bracket to the hub
and even then there were only 4 either side
04-05-2008, 10:39 AM
On some kits there are spacers to align caliper properly so that the disc is exactly in the middle of the space between pistons.
04-05-2008, 11:31 AM
Former Sponsor
dojj
thats how it should be,dont go spacing incorrect brackets with washers etc on brakes,if it does not fit get the brackets made that do,martin at reyland makes brackets.
04-05-2008, 12:11 PM
awesome thc for you help all sorted ! !
does anyone know the torgue of the bells and caliper mounts???
thx alot
regards
Dene
04-05-2008, 12:16 PM
are they similer to mine?
04-05-2008, 01:04 PM
yes mate pretty much the same the calipers are satin black tho
cheers
04-05-2008, 02:51 PM
rsdene
thx alot
regards
Dene
14nm
or 10ft/lbs
ok, that's the bell to disc torque
the bracket to hub is as tight as you would be able to do it up, i did it up to just under 60nm
the caliper to bracket's i did up to they were tight, then nipped it up just about 10 degrees
04-05-2008, 03:24 PM
dojj
14nm
or 10ft/lbs
sweet thanks alot
all sorted
james kiely
28-08-2015 08:58 PM
SteveyDee
24-08-2015 05:43 AM
Dahl88
22-08-2015 08:16 PM
RsS2daz
14-08-2015 05:26 AM
col93saphcos
07-08-2015 03:21 PM
