anybody use or seen 1 of these
Guest
Posts: n/a
well they look like an essential bit of kit for all turbo charged cars and its a rally/race spec part price is worth a try decreases air temps by 30 odd deg what dya think?
http://www.rallynuts.com/motorsport/...s_NEW_1528.asp
1 Post
looks like it uses a CO2 bottle to freeze a section of inlet pipe down to many below zero, as above, the kit also needs the bottle which is over 300 quid, could justify it if u were VERY short on space .
#1 in Spelling Club
It is a section that you fit to the Inlet tract that contains an aerodynamic 'Teardrop' shaped object that is cooled using CO2 so that air passing over it is also cooled.
Yes you do need the initial CryO2 system, but it will run more than one of the accessories.
I can supply these........
(I haven't tried it myself yet, but if I had the dosh, I certainly would!!)
Guest
Posts: n/a
wikid christian i,ll be in touch im deffo haveing it daft not to i think whats best price? also the sprayer that ataches to cooler i take it as its small compared to cooler you,d place it on the corner were your pipework for the air intake to the engine is? best place id think?
