torque stages for a cosworth head??
Old 27-04-2008, 11:03 AM
B13 JUS
B13 JUS's Avatar
Default torque stages for a cosworth head??
what is the torque stages for a cosworth head? i've been told two different way's. 30nm then 70nm then a 90 degree's turn or 25nm then 50nm then a 180 degree's turn.
what is best???
Old 27-04-2008, 11:06 AM
The DIVA
The DIVA's Avatar
I do 25,50 then 90degrees then 90 degrees
Never had a problem in over 20 years
Old 27-04-2008, 11:07 AM
B13 JUS
B13 JUS's Avatar
do you check them again after it's been run for a bit??
Old 27-04-2008, 11:09 AM
The DIVA
The DIVA's Avatar
After a couple of hundred miles i just check them at 95 foot pound on the torque wrench
Old 27-04-2008, 11:12 AM
Ryan
Ryan's Avatar
asked this same question, both are fine, as the end result is the same, personally i prefer the 90 90 method, as trying to do 180 around the engine bay is a coooooooont
90/90 is much easier.
B13 JUS
B13 JUS's Avatar
after you have done the final 90 degree's turn do you check them all at 95 foot pound??
forgot to mention i'm using a cometic gasket with stanard bolts, this does'nt make a differance does it?
Old 27-04-2008, 12:11 PM
Lee Ivatt
Shizzle My Nizzle
Lee Ivatt's Avatar
yeh 2nd that. 180 is pain in arse and also seems way ott. plus you look like ur doing some sort of yoga/ti chi practice doing 180 turns with a big bar
big_Rad
15-09-2017 09:36 AM
SmudgerByName
52
28-07-2016 06:14 PM
salsheikh
Alloy wheels and ICE for sale
20-08-2015 12:33 PM
14-08-2015 07:29 AM
salsheikh
30-07-2015 08:45 PM
Quick Reply: torque stages for a cosworth head??
