FAO Stu/ MSD Boys Re: Evo Chips
Guys,
Do you do an evo chip for the BMW 540i 1993 (M60 engine) ?
I had a look on the website but it only listed the newer M62 as found in the E39 and E34 chips stopped at the 535i.
If available what sort of gains are to be had ?
Also, who would be your nearest dealer to South London to install if available ?
Paul
Paul
Testing the future
as you have found by doing a chip search, your particular model is not listed (although could it not be the same as the 4.0 version listed for the E39?), but we'll wait and see what stu can confirm
to find your nearest dealer, just follow the link on the evolutionchips.com website
http://www.evolutionchips.com/dealer2.html
there isn't one particularly close, but some are mobile like me, so would happily come to your home or place of work
The E39 4.0 is actually a 4.4 (M62 motor with vanos) as opposed to the older M60.
There's a couple of dealers in/ around London which I'd no problem getting to, it just if a chip dosen't yet exist, I presume I'd have to go up to MSD to get it sorted ?
Testing the future
not necessarily - it's rarely an actual chip these days anyway. more often than not the map is written into the ecu via the diagnostic port rather than having to remove the ecu and plug in a chip.
it may be the case that stu can send a file to a dealer - let's wait and see what he says.
wheelwizardrefurbs
18-09-2015 08:59 PM
