Open front diff or lsd on a 4x4
Old Apr 20, 2008 | 07:41 PM
escossie560's Avatar
escossie560
Default Open front diff or lsd on a 4x4
After yet another great day of smashing transmition parts at pod, ive been thinking of removing my front atb diff and going back to an open diff to remove some of the tension on my drive train when launching .......what do people think will this help much
Old Apr 20, 2008 | 08:00 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
nope, still a shitty little 6.5" diff, go for a R&D 7" unit at the very least, I have a thinkwall 909 diff and am worried about breaking that..... Doug stirling cracked his thickwall casing in half ... Launching a 4x4 cos with big power will mean spending 10k+ at least on the tranny...... or it's wreck and repair on the cheaper stuff, simple as. Good as the Mullet boxes are, the mainshaft will always be a problem as you have to work your upgrades into the original dimensions.
Old Apr 20, 2008 | 08:12 PM
escossie560
I have a thick wall front with an atb dont think i can go back to open as the casings have to be machined. I have the mullet box but it only has the gear kit not the shafts (which is why i came home on a bar) But i keep snapping drive shafts i think the diff is one of the big reasons due to the fact the atb locks so when one wheel finds grip it rips the other apart.
Old Apr 20, 2008 | 08:28 PM
Kelv's Avatar
Kelv
Almost there!
Wil - im guessing youve already looked into costs of the R and D front diff.
do you know the costs etc, and are you able to still use the standard driveshafts - i reffer mainly to the drivers side shaft.
both of my Diffs are currently ATB aswell.
Old Apr 20, 2008 | 08:31 PM
Gary F's Avatar
Gary F
Might be a daft question but have you checked your engine mounts?
Old Apr 20, 2008 | 08:33 PM
Dannn's Avatar
Dannn
Convert to 2wd - fixed!
Old Apr 20, 2008 | 09:02 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
As i have said eralyer, keep the standard diffs, because of the way they work, they have the right amount of grip to get the gearbox to hold together, and it´s wery simple to get them to last
Old Apr 20, 2008 | 09:42 PM
markk's Avatar
markk
if an ATB loses traction the wheel that is slipping then revieves all the power mate. hence why ATB's are really poor, as long as you can maintain equal drive they work, if not they are about as good as an open unit. the ATB never locks, is a pre-loaded torque biased unit.
Old Apr 20, 2008 | 09:52 PM
RWD_cossie_wil
I belive you can use std shafts, and an R&D unit goes from anywhere between £1400-£2800 from the ones I have seen sell.
Old Apr 21, 2008 | 09:54 AM
Turbo lag's Avatar
Turbo lag
What do you do to the difs Cossiemanden ?
Dave.
Old Sep 30, 2008 | 08:23 PM
ECOS95's Avatar
ECOS95
Dave.
Seconded.
Old Sep 30, 2008 | 08:47 PM
blacky.'s Avatar
blacky.
loose a load of weight from the car & they will last better
Old Sep 30, 2008 | 08:48 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
i have a atb for sale,in the correct forum, and it has been faultless with 600bhp and 50/50 torque split
3i Jim
Nov 20, 2015 05:12 AM
Chas
Sep 21, 2015 08:57 PM
FlashRS
Sep 14, 2015 12:36 PM
C2 MAK
Aug 20, 2015 09:46 PM
Old ford
Jul 31, 2015 06:50 AM
