Cossie Coilpack conversion......
15-04-2008, 08:35 AM
#1 in Spelling Club
Regarding Stu's Coilpack conversion, where/how do you guys mount the coilpack?
15-04-2008, 08:36 AM
Mines on a bracket in the same place as the normal coil...
mines on my strut brace.
most mount them either infront of the header tank on a 2wd or a 4wd, some up behind the turrent, and escorts the same, or behind the plastic scuttle.
15-04-2008, 08:42 AM
Ryan : When & where is the next Hampshire meet.....????
15-04-2008, 08:45 AM
Jim:
Monday 21st April
West Meon Pub off the A272
15-04-2008, 08:47 AM
Did Someone Mention TUV
Quote:
Originally Posted by
Ryan
Ryan,
What strut brace have you got and did you butcher the 2wd heat shield to make it fit?
Rolls
That's the usual place
15-04-2008, 08:49 AM
i have a Philloy item, i.e same as GGR/Tarcal.
Fitting the sheild this week hopefully, waiting for a bracket to turn up which should be here today. Think i have to trim some off of it though.
16-04-2008, 03:04 PM
TKS Ryan......See you there.
Sorry to darken the car park with the M5.
16-04-2008, 03:30 PM
Monte 087
Mine is where the origional coil mounted.
16-04-2008, 03:39 PM
Unknown.
16-04-2008, 04:04 PM
Mine is on a bracket under the plenum, sort of right next to the dizzy!!
16-04-2008, 04:36 PM
Rolls
Mine too.
16-04-2008, 05:48 PM
16-04-2008, 09:10 PM
i had my old map sensor bracket modded and the coil sits down there now
16-04-2008, 09:18 PM
16-04-2008, 09:19 PM
Fae the Dale
I want to run coil pack. 4x4 sapph, what do i need? Where can i get a conversion kit from?
16-04-2008, 09:24 PM
heres mine mate near amp bracket
16-04-2008, 09:27 PM
Unknown.
BIG WULL
http://www.motorsport-developments.co.uk/
16-04-2008, 09:47 PM
Fae the Dale
cool. Cheers. take it they can supply an fit this type of conversion?
Would do the work myself if a kit was avalible.
I'll ring tomorrow.
16-04-2008, 09:50 PM
Unknown.
I'm sure they supply it as a kit, Look for a contact number and ring, its Stu@MSD on here!
16-04-2008, 10:51 PM
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
IainRS1700T
25-09-2015 06:44 AM
