xr3i efi to ofab issues
ive sort of worked out how to wire in the supressor/map sensor. Thing is on the ofac map sensor plug the black/brown wire (ecu pin26), do i wire this directly to the black/brown wire on the ofab map sensor plug?
and ive worked out that i run the brown/yellow and brown wires through the suppressor? is that correct?
ive looked at rsbible and it isnt really clear enough and i dont want to damage my ecu.. This is all thats stopping me from my car running so help asap would be most helpful.thanks
or even if someone knows who i should speak to......as working it out to run through the supressor,only two wires go to the ofab map sensor plug.....the yellow and the brown/black so where does the brown wire on the plug go to????im getting really confused!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
hi mate,dont think you read my post properly,i said ive looked on there but its not clear enough.......................................
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
